Ignition switch?
Old Nov 1, 2015 | 01:15 PM
mlrailguy's Avatar
mlrailguy
Default Ignition switch?
This spring, I started my 06 Sporty 1200. While putting on helmet and gloves, it just died, as if someone had cut the battery cables. The instruments weirded out, flashing and all, when I turned key to ACC, but when turning all the way to IGN, all black. I had replaced both cables at that time, and all was well.
Today, I go start it, and dead again. The battery tender is steady green, so I know battery is still good. Could it be ign. switch? I have already taken all cables loose, retightened, and still no ign. Guages light up in ACC
Old Nov 1, 2015 | 03:23 PM
willg's Avatar
willg
I had the same issue on mine. 06 roadster 1200. Replaced switch two times. This one seems good so far.
Old Nov 1, 2015 | 03:31 PM
JustOneDean's Avatar
JustOneDean
As far as I know, the only components all your electrical circuits have in common are the battery, the main fuse, and the ignition switch. If you're positive it's not the battery and the fuse is good, then it's probably the switch or one of the wires connected to it. Do you have a multimeter?
Old Nov 2, 2015 | 06:45 AM
mlrailguy's Avatar
mlrailguy
Going to town tonight to get one
Old Nov 2, 2015 | 11:55 AM
JustOneDean
All right. Do you know how to use it/what to check?
Old Nov 2, 2015 | 12:37 PM
mlrailguy's Avatar
mlrailguy
have a vague idea on how to use it, but don't know what or where I should be looking
Old Nov 2, 2015 | 01:16 PM
sgthwjack's Avatar
sgthwjack
Worth every cent, experience! Learned the hard way myself.
http://www.ebay.com/itm/HARLEY-DAVID...BWMYIW&vxp=mtr
(an example listing)
Old Nov 2, 2015 | 02:28 PM
JustOneDean
What do you know about it? Are there any specific questions you have? Post a picture of the one you got and I'll probably be able to help with the basics.
Old Nov 3, 2015 | 10:24 AM
Crispy Nubbins's Avatar
Crispy Nubbins
If your buying a meter get a Fluke. Don't waste money on a cheap meter. You'll get more use & longer life from a good meter. And a good meter that reads amps helps if you have a battery draw you need to test.
Old Nov 20, 2015 | 07:50 AM
mlrailguy's Avatar
mlrailguy
Finally getting back to bike. Here is a pic of meter I picked up.
