Dash unit malfunction
Old Dec 8, 2015 | 09:45 PM
Thetomcat's Avatar
Thetomcat
Stage IV
Default Dash unit malfunction
Today I went to start my bike (2013 sportster 72) and the entire dash unit stayed off while the bike was running. I then shut the bike off and re-started it and the dash unit began to work. Then I got home shut it off and later started it again and the same issue occurred. But the strange part is the dash unit works when I turn the ignition on but as soon as the bike fires up, it cuts out. My headlight and brake lights still work, as well as the high beam. But not the turn signals. I took the bike in last week for a new stater, not sure if it's just a coincidence or if the installation of the new stater had an effect. But it's very annoying because the speedo does not move when I'm at speed, nor does my gas light turn on when I'm running low. (I know because I ran out of gas today) has anyone had this problem before? Or heard of it? If so any suggestions?
Old Dec 9, 2015 | 07:01 AM
somorkc's Avatar
somorkc
Check the connector inside the speedo. Also check the same harness connector where it connects under the tank. Last but not least the fuse box for any associated fuses.
Old Dec 10, 2015 | 12:30 PM
Thetomcat's Avatar
Thetomcat
Stage IV
Feel like an idiot. It was a blown fuse. Thanks brother.
PHA-Q
Mar 10, 2012 12:30 AM
Renoir1
Nov 6, 2010 12:22 AM
mpetrie610
Shovelhead
Mar 16, 2010 08:00 PM
Sullyboy
Aug 3, 2009 09:34 AM
ChefE
Apr 24, 2008 01:09 PM
