05 - 1200c problems - should I expect anything else?
Old Nov 27, 2005 | 07:09 PM
MegaHDman's Avatar
MegaHDman
Default RE: 05 - 1200c problems - should I expect anything else?
Do yourself a favor, go aftermarket when it comes to performance goodies for the bike in the future. I am not a fan of many of the "Screamin Eagle" products that HD offers.
The belt is not covered under warrenty. Since it is a wear and tear item, and debris could damage it, your going to be stuck with that one, unless your dealer is exceptional, they wont do squat. Thats just bad luck on your part. What exactly was the broken chrome rear heat shield? Where is it located? Do you mean belt guard?Or the exhaust heat shield? Show a pic? If a factory weld broke they SHOULD REPLACE that, I would insist that they do if I were you. Especially such a cheap part.
The top rocker box gaskets do have a new revised replacement part, I think this is already covered under the warrenty. Should be willing to replace no charge. The valve seals are known to have issues, best thing to do is to send your heads to an independant shop(Like www.nrhsperformance.com ) that specializes in XL motors, have them do a mild port and polish and replace the seals,locks and collars. At least you will gain some good hp from the work and your heads will be very reliable then. Are you seeing bluish smoke coming from the exhaust? Or do you smell alot of burnt oil? Good way to tell quickly if you do have a head problem. If you see alot of blue smoke, your burning oil, should have a compression and leakdown test performed to see what the problem is.
Overall the bike really is rock solid. Other than the bad luck on the voltage regulator and the belt you should be good to go. BTW, make sure that rear belt is properly adjusted. And a tip for you, its better to have the belt a bit looser than too tight. You never want your drive belt adjusted too tight.
Old Nov 27, 2005 | 07:33 PM
Wolhar's Avatar
Wolhar
Is this dejavu or something? What the hell is going on here? I thought we had been through this all before.
Old Nov 27, 2005 | 07:37 PM
pococj's Avatar
pococj
Gotta remember to look at the dates on the posts!
Old Nov 27, 2005 | 08:42 PM
MegaHDman's Avatar
MegaHDman
I assumed the post was rather new since it was the first time I saw it. [8D]
Old Nov 28, 2005 | 03:18 PM
molsenice's Avatar
molsenice
Problem solved
problem solved
tropic365
Exhaust System Topics
Oct 11, 2019 12:08 PM
wildpig1
Milwaukee Eight (M8)
Apr 27, 2017 04:28 AM
PREACHER
Mar 22, 2007 07:15 PM
molsenice
Sep 30, 2005 02:07 AM
mndemohead
Jul 28, 2005 01:21 AM
