Help with front wheel fitting? Urgent please
Old Apr 24, 2016 | 01:22 PM
multihdrdr's Avatar
multihdrdr
The bearings were probably installed in the wrong sequence. They installed the Non Disc (right) side first (deeper pocket) when they should have installed the "Primary" Side (Disc side, left side) first...
This morning I got a chance to measure the bearing bore depths of a 08-later Sportster narrow-glide laced spoke wheel (it will represent the Iron's 13-spoke wheel)
The Right-side bore depth is .105" deeper than the "Primary" side (left-side). So if someone incorrectly installed the Right-side bearing first, the wheel could be shifted up to .105" to the right from where it was originally located.
INSTALL LEFT SIDE FIRST (Brake Disc side)
They may have just inserted both bearings and if using a threaded "draw" bar (basically long bolt or all-thread) just starting pulling both bearings in at the same time and what you got was what you get "up to .105" offset"
Old Apr 25, 2016 | 07:09 AM
harleyglen's Avatar
harleyglen
Many thanks for your input guys, really appreciate it
It appears that the bearings have been installed incorrectly. After a better look I can see that the disc side bearing fits pretty much flush with the edge of hub and the right side bearing sits about 8mm in. After talking to a tech guy he said its crucial for the disc side to go in first as it acts as the wheel alignment so now the wheel is pushed over to far. I have ordered another pair of bearings and the garage is going to pull them out and refit new ones in correct order.
Harley tech guy said its a common mistake and my garage is actually a Honda dealer so prob not of known as I never.
I chose them as gave good price on my white wall tyres and 5 mins from home so thought get them to do bearings rather than take wheels away to a Harley garage.
Hopefully get it sorted and back on the road soon!
Again thanks for taking the time multihdrdr to measure your bike
just plain john
General Topics/Tech Tips
May 21, 2019 06:43 AM
FatboysFatboy
Wheels/Tires
Nov 27, 2012 09:30 PM
big_e78
Mar 8, 2010 10:51 AM
greywolf77
Jun 5, 2007 04:28 PM
03RKC
Apr 5, 2007 09:01 PM
