Yea Ive tried to move it back anf foward it still wont get in gear. Running or not,so im gonna check on fluids and adjustments now and see what happens.Thanks for the help. Oh yea,,, so yas dont think its transmission then?
Did you hear it run when you bought it? How do you know it has compression and the motor isn't seized? It should shift without the bike running, I would pull the clutch cover and see what's in there. Does the cable have any movement?
Your really not giving us much information. You can still shift if the motor is not running.
Does the shift arm move freely or with a click/notch sound, do you feel resistance or does it just flop down all the way. Dies the clutch lever and cable pull in when you squeeze it.
