Harley Sportster Engine Temperature Sensor (ET Sensor)
Old Sep 19, 2017 | 06:39 AM
monishrpatel's Avatar
monishrpatel
Default Harley Sportster Engine Temperature Sensor (ET Sensor)
I own a HD superlow xl883l 2013 and have got an error code P0118. Upon contacting workshop they feel its an issue with ET sensor or the wire connecting from sensor to ECM.
I was wondering where to ET sensor is located and could'nt find it though. Workshop claims its between the two cylinders in Sportster models.
Can anyone help me locating it.
Also attaching photos of the throttle inbetween both cylinders from both sides.
Thanks
Attached Thumbnails Harley Sportster Engine Temperature Sensor (ET Sensor)-whatsapp-image-2017-09-19-at-5.07.38-pm.jpeg   Harley Sportster Engine Temperature Sensor (ET Sensor)-whatsapp-image-2017-09-19-at-5.07.38-pm-1-.jpeg
Old Sep 19, 2017 | 07:09 AM
cvaria's Avatar
cvaria
it's on the rear head. you will see a wire, on the riders right side of the bike, in front of the oil tank, running up to the rear cylinder head.
kinda hard to get out with the right tools. follow the wire and check for abrasion of it being disconnected on the from the bike's harness before trying to change it. may just be dirt in the connection. hit the connections on the bikes harness side if te wire with some electrical contact cleaner a tiny bit of dielectric grease. see if the code stop returning afte being cleared. i had that isse with my dyne temp sensor, fixed the random codes and rough idle.
if you need to change it then you can make a tool to get it out, buy the hd tool, or have the dealer do it.
i made one here. total P.I.T.A.
https://www.hdforums.com/forum/sport...mp-sensor.html
Old Sep 19, 2017 | 07:24 AM
monishrpatel
is the et sensor inside the rear cylinder and connecting to ecm or the sensor is located inbetween two cylinders?
Old Sep 19, 2017 | 07:36 AM
Ratwerke's Avatar
Ratwerke
It's the wire running down the center of the rear rocker cover.
Sensor is on top of rear cylinder.
Old Sep 19, 2017 | 07:52 AM
monishrpatel
thanks! will check it and get back.
Old Sep 19, 2017 | 10:44 AM
lewk's Avatar
lewk
Ermmm.... maybe take the pic on the other side of the bike next time?
Old Sep 19, 2017 | 03:35 PM
monishrpatel
Ordered for OEM replacement part.
Did you have to remove cylinder from the frame for changing the sensor or you could do it from above while the cylinder was in frame?
If you had to remove it out of the frame did you happen to change the gaskets of rocker or you just changed the sensor and it was done.
Thanks
Old Sep 19, 2017 | 04:18 PM
cvaria's Avatar
cvaria
Thanks
did you try cleaning the connectors and check the wire for damage first? i changed it while the heads were off.
Old Sep 19, 2017 | 04:31 PM
monishrpatel
OEM part was costing me around $48 so considering to replace it directly.
For checking it probably i will have to get the cylinder down and if the part is faulty will have to place the order and wait for it so just considered to order it first and than take down cylinders.
You had to change the sensor or cleaning did the work?
Old Sep 19, 2017 | 06:11 PM
cvaria's Avatar
cvaria
there's conflation happening. i'm saying. follow the sensor wire, from the head, down to where i connects to the bike harness. check for damage to the wire along the way. disconnect the wire from the harness, clean it, and reconnect it. after that clear the code that it is throwing and take it for a long ride. no need to tear the bike apart. if the code shows up again, then consider replacing it.
my dyna et sensor was randomly throwing codes and causing rough idle. i cleaned the connection and it has behaved ever since [fixed].
A. problem- see #3 at the bottom: https://www.hdforums.com/forum/dyna-...l#post16283313
B. fix- https://www.hdforums.com/forum/dyna-...l#post16292667
on my sporty, i just replaced my et sensor since i replaced my entire top end and it was pinched pretty bad [in bad shape]. that sensor i removed still worked and is now a spare in the bucket-o-parts.
see bottom of post:
https://www.hdforums.com/forum/sport...l#post16142615
damaged
