Pull back riser 1200T
Old Sep 24, 2017 | 02:16 PM
Colin1966's Avatar
Colin1966
Originally Posted by 2ndTink
I have a 14 xl1200t, risers are cast into the triple tree. I looked at changing the risers or bars, there were some spacer blocks that would lift them straight up, I looked at a lot of different bars. If you go the bar route, keep an eye on the width tip to tip, she might not like them much wider than stock. I never pulled the trigger on bars though. It's an excellent bike though, totally enjoy it, just painful leaning forward all the time to reach the bars.
"risers are cast into the triple tree."
Exactly,
we were going to swap the upper tree but way too much work.
I did see the LA Choppers 2" rider extensions
http://www.ebay.com/itm/LA-Choppers-...53.m1438.l2649
Then started looking into the Buckhorns as they have a rise & pull back.
This all stated after she swapped out the seat so I am thinking the extensions and lowering the bars maybe the ticket??
Colin
Old Sep 24, 2017 | 02:28 PM
2ndTink's Avatar
2ndTink
Might catch some flak for this one, but while I was looking at all the options, I found Rox pivoting risers, seems mostly metrics are comfortable with this, but what I was thinking was a set of those would let you play around with the positioning of the hand controls. When you find where it suits her, take the dimensions from the risers up to the hand controls and then you'd know what dimensions on new bars to get. Or just leave them, heck with what people think, if it makes the ride more enjoyable, it's much better having a bike going down the road than sitting in the garage because its no fun to ride. They came is 1 to 4 or 6" lengths.
I'm 5'4" on the same bike with a Mustang seat, I can vouche for your wife on reaching for the bars being a complete pain! Just moving to a softail in the next week though, but of course have the same handlebar issues with the Heritage...
Old Sep 24, 2017 | 02:56 PM
Colin1966's Avatar
Colin1966
I did see them and I think they are a kool setup as you actually rotate the riser and bars separate, WAY more adjustable..
Another option :-)
Thanxs
Colin
Old Sep 24, 2017 | 06:40 PM
2ndTink's Avatar
2ndTink
Only problem is, you can get some bars for less than they cost. But, seems you could go through a lot of bars (same as seats) looking for just the right set. Unless you are buying solely for looks.
Old Oct 11, 2017 | 02:11 PM
Colin1966's Avatar
Colin1966
I picked up a set of LA Choppers Handlebar Riser Extension 2".
I straightened out the brake line & re-routed the clutch cable and she says she likes the way it feels, but wont find out until next Spring as her bike is off the road.
Thanx for the info
Colin
Attached Thumbnails Pull back riser 1200T-img_4903.jpg   Pull back riser 1200T-img_4905.jpg
rowdyj
Jun 12, 2014 07:45 AM
ghoticov
Mar 8, 2013 04:45 AM
j88j
Oct 19, 2010 06:28 PM
DynaRyda06
Jul 18, 2010 10:36 PM
stormcooker
Dec 21, 2009 02:01 PM
