Well, if it keeps you from wanting to ride your bike it's both
__________________________________________________ ____ For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
Its whatever you can live with. Mine has S&S rocker arms, S&S premium lifters and rocker lockers. It is very quiet compared to most Sportsters. It still has some mechanical noise but not the loud ticking some get. I did not do this for the noise though.
I'm not sure this 'problem' is looking for a solution! Is this noise due to faulty valve clearances? If in doubt start by getting an expert to listen to your bike, to identify if it needs attention. My Sporty is fine, but then I have other Harleys to compare it with.
