1200 cab neutral light
Old Jun 25, 2018 | 05:49 PM
Eagle15's Avatar
Eagle15
Default 1200 cab neutral light
My neutral gear indicator has stopped working is this an easy fix ?
Old Jun 25, 2018 | 05:59 PM
John Harper's Avatar
John Harper
Is it the bulb, or the switch?
Old Jun 25, 2018 | 06:05 PM
HOTLAP's Avatar
HOTLAP
Have you done any other work lately (wiring or otherwise) that coincides with when this problem started?
Old Jun 26, 2018 | 02:38 AM
Eagle15's Avatar
Eagle15
To be honest I don’t know the cause.
And I haven’t done any work recently.
i thought I have been having trouble selecting neutral on a few trips but it was the light not always coming on
Old Jun 26, 2018 | 01:24 PM
HOTLAP's Avatar
HOTLAP
You will need a wiring diagram from the back of the service manual to diagnose the problem, it should be very simple as there is a neutral switch on the transmission, the wiring to it and then up to the dash, and the bulb itself.
Depending on the year the power may go first to the switch then up to the light and to ground, or sometimes the power may go to the light first then travel down to the switch and go to ground from there.
Either way once you consult the proper wire diagram for your bike you can use a multimeter to trace power and determine if it is a wiring issue, switch issue or bulb issue.
37sportster
Nov 20, 2020 03:40 PM
Dante221
Jul 1, 2018 01:38 PM
Pops
May 26, 2010 05:29 PM
yso191
Sep 13, 2009 09:09 PM
fxdctom
May 20, 2008 07:53 PM
