Lithium battery
Might find some good info on it online, but I believe the warm up period only applies when temps get below 40*, maybe lower.
Am curious about them as I think I have a new battery in my future as well. I assume the charge controls are built in to the battery, so no changes needed for the bike itself?
Is it in full size case, same as old battery?
Finally, cost?
My 1991 has zero parasitic drain, unlike newer bikes, so a tender may be a good idea for long term storage if you have a later model, especially EFI.
John
My 2013 Service manual shows the stock AGM as:
Harley Davidson (65958-04)
225CCA CCA @ 0F
12Ah
The HD Lithium:
'04-'13 XL models require separate purchase of Hardware Kit P/N 66000234.
https://www.harley-davidson.com/stor...fe-4ah-battery
HD 4Ah Lithium Battery Part Number 66000171
The battery is 5 3/4 inches tall, 5 15/16 wide, and 3 7/16 front-to-back.
2.2 lbs
CA 160 @ 20F
CA 240 @ 60F
HD 6Ah Lithium Battery Part Number 66000174
2.8 lbs.
CA 240 @ 20F
CA 420 @ 60F
HD 8Ah Lithium Battery Part Number 66000175
3.34 lbs.
CA 320 @ 20F
CA 480 @ 60F
