more problems
Old Mar 10, 2020 | 02:53 PM
gerald martin's Avatar
gerald martin
Default more problems
Hi
I now have more problems with my 2015 sportster 883 with 1200 conversion kit. Just driving along. bike just shuts off. Look for codes none. Hit the start button and it starts and runs fine. Took battery out went to battery shop they tested it all was good load test good cranking power and fully charged. When i took the battery out every thing was tight, checked the ground cable and the power cable every thing good. I just had a direct link tuner put on. When i first put it on it stalled and I got 3 codes Po132 front sensor rich, Po152 rear sensor rich and PO507 could not find that one. Took it back to tuner, he adjusted things and said it was good to go. road it for 200 miles and it stalled again but no codes this time Any ideas what the problem is?
Old Mar 10, 2020 | 03:07 PM
Bass Player's Avatar
Bass Player
Tuner...wrong setup or possibly defective. Plug n play? Could be the hookup itself either way?
Old Mar 10, 2020 | 05:17 PM
handirifle's Avatar
handirifle
Remove the tuner and road test the bike. Might run lean but if it does not shut off then its the tuner. I would ask for replacement or money back.
Old Mar 12, 2020 | 06:33 AM
grbrown's Avatar
grbrown
Lightbulb
Originally Posted by gerald martin
Hi
Visit your tuner again! He can put his hands on your bike and check it over. Did he supply and fit the 1200 kit?
David Butler
Aug 8, 2019 09:52 AM
David Jeremy Dickson
General Topics/Tech Tips
Aug 13, 2018 03:55 PM
883rTorres
Aug 14, 2014 03:47 PM
bykeguy
Mar 19, 2008 06:31 AM
Racingcodyman
Mar 22, 2007 11:31 AM
