Oxygen Sensor Question
Old Mar 26, 2020 | 02:59 PM
cdoubleuc's Avatar
cdoubleuc
Stage III
Default Oxygen Sensor Question
Hello, I have a question about my 2014 Sportster 883.
Battery died recently, replaced it with a new one. Since then the check engine light comes on when I go faster than about 60 mph, it remains on as long as I am above 60, when I slow to below 60 it goes off.
Seems to idle fine, and accelerate good, but when I give it very little throttle (maintaining speed) it's a little sluggish.
Checked error codes, got PO151, PO152 and PO154 (Oxygen Sensor, I believe)
wondering if anyone has any ideas?
Thanks
Old Mar 27, 2020 | 07:47 AM
tmac00333's Avatar
tmac00333
Thanks
As per the electrical diagnostic manual
Possible causes
PO 151
Rear 02 sensor malfunction
ECM malfunction
Short to ground in signal circuit
Fuel system malfunction
PO 152
ECM malfunction
PO 154
ECM malfunction
Open or short voltage in signal circuit
Open sensor ground
Old Mar 27, 2020 | 09:34 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
From the sticky above
P0151 Rear Oxygen Sensor Low
P0152 Rear Oxygen Sensor High
P0154 Rear Oxygen Sensor Inactive
It could be a bad connection that shows up at speed due to vibration. It could be a faulty sensor for the same reason. If you have the correct socket tool you cold swap them and see if the fault moves to the front O2 sensor.
Old Mar 27, 2020 | 09:49 AM
cdoubleuc's Avatar
cdoubleuc
Stage III
Ok, I'll try that.
Thanks, I appreciate your suggestion!
cdoubleuc's Avatar
cdoubleuc
Stage III
OK, thank you!
Brandon Jackson
Aug 15, 2019 10:52 AM
rebel7
Aug 7, 2017 09:36 AM
NightTrainRob
Sep 23, 2015 10:44 PM
Tropical Andy
May 13, 2008 04:06 PM
jwiz
Jun 18, 2007 10:32 PM
