Clutch problems fourty eight 2017
Old May 24, 2020 | 05:50 PM
Lromine1997's Avatar
Lromine1997
2nd Gear
Default Clutch problems fourty eight 2017
Did adjustment on clutch inside derby cover I did it properly (not first time) went to adjust slack in cable but it seems to only tighten inside the derby. Clutch lever does not pull in. Need help would like to ride again!
Old May 24, 2020 | 08:36 PM
Madnss's Avatar
Madnss
repeat the process, make sure the cable is pushed into the primary all the way. Adjust it, then set your slack
Old May 24, 2020 | 08:57 PM
Lromine1997
2nd Gear
I made sure everything was good when I adjust slack in cable the ramp tightens
Old May 24, 2020 | 09:01 PM
Ed Ramberger's Avatar
Ed Ramberger
You adjusted the ramp overcenter. Loosen the cable and the clutch adjustment at the derby cover. Then push the cable all the way in toward the clutch release in the primary - you need to be on the base of the ramps. Then do the clutch adjustment, then do the cable adjustment.
Old May 24, 2020 | 09:05 PM
Madnss's Avatar
Madnss
exactly, my explanation was a little brass haha
Old May 24, 2020 | 09:57 PM
Ed Ramberger
And in case it wasn't clear, make sure that the release lever the cable hooks into moves all the way back toward the rear wheel after loosening everything before adjusting anything.
Old May 24, 2020 | 10:02 PM
Lromine1997
2nd Gear
I just tried again pushed toward rear adjusted and put nut on to keep in place. Went to adjust lever and it still tightened. So after that I did it again held it toward rear and adjust a little on cable. Both ways the lever is really hard to pull
Old May 25, 2020 | 05:23 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Seems like you have something wedged in at the lever end.
Very simple to remove the circlip and pin to release the lever.
Old May 25, 2020 | 09:52 AM
Lromine1997
2nd Gear
I removed lever yesterday and took the cable off the lube but didn't notice anything stuck. I took ball and ramp out readjusted them put back in and it's still the same. Could it be the cable itself? The bike usually sat outside on the porch. I had it to where it was rideable last week but would slip at full throttle in 4th and 5th. Decided to try to fix and now the lever is extremely hard and will not dis engage. There is more room for ramp to move but the cable wont pull any further
Old May 26, 2020 | 06:32 AM
Lromine1997
2nd Gear
update: removed primary and found some chunks of metal. Looked in slots where clutch plates are and there are more chunks in there. Have to wait until I get spring compressor tool and then clutch plates before I open her up.
Lromine1997
May 24, 2020 05:52 PM
tylerfj24
May 28, 2019 11:19 PM
bigdog bigdog
May 29, 2011 01:48 PM
Wally
Jun 5, 2010 08:00 AM
windsoreight
EVO
May 24, 2009 07:58 AM
