TMAP Replacement
Old Jul 23, 2020 | 02:04 PM
iamjacks12's Avatar
iamjacks12
Stage III
Default TMAP Replacement
Got a 2010 Sportster Forty Eight. I need to replace the TMAP sensor. Having a difficult time getting the old one out. Seems to be blocked by the throttle bracket. Has this little hood preventing extraction. I cannot get sufficient leverage on the torx screw to get it off. Thoughts?
Old Jul 25, 2020 | 02:41 PM
iamjacks12's Avatar
iamjacks12
Stage III
Update****New Issue
Started last night, same issues ran rough. Same p0108 code: TMAP sensor. This was replaced today. Now the bike wont start. Its almost as if the fuel isnt getting to the injectors. Now when I run the codes. I am getting several no rSP...any suggestions out there???
Old Jul 25, 2020 | 06:42 PM
John Harper's Avatar
John Harper
Did you connect all the wires to the battery? I've read of people missing the second "red" wire to the positive side.
Can you reset the electronics/ECU? My bike is an old carb model without all the fancy electronics, so I may be off base on this suggestion.
Seems like a simple procedure, you must have overlooked something if all you changed was the sensor. I've changed sensors on my truck and never had an issue.
John
Old Jul 26, 2020 | 03:04 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
The fault code might be due to a bad connection or faulty wiring. The error code could also be displayed if the fault exists in the ECM.
With multiple codes I would check the wiring loom and connectors.
Diagrams here - https://serviceinfo.harley-davidson....t/view?id=5537
Old Jul 26, 2020 | 03:48 AM
shanneba's Avatar
shanneba
Your TMAP sensor may not be bad, check the wiring/connectors for the other sensors on the 5V reference.
Intermittent TPS malfunctions may cause the TMAP to set a code prior to the TPS codes setting.
The TMAP, JSS, TPS and VSS are connected to the same 5V reference line.
A faulty sensor can negatively affect the signal voltage of the other sensors sharing the same 5V reference.
Check your CPS Crank Position Sensor wiring, if the ECU does not get a signal from the CPS it will not fire the injectors and ignition.
Old Jul 26, 2020 | 02:36 PM
b0fh's Avatar
b0fh
about removing it... you will have to 'fabricate' a tool by cutting a torx bit as short as you can to fit it in there.
Old Jul 26, 2020 | 02:43 PM
Andy from Sandy
From the 2008 FSM
1. Unplug Maxi-Fuse. See 7.34 MAXI-FUSE.
2. Remove air cleaner cover, air filter element and backing
plate assembly. See 4.3 AIR CLEANER.
3. Remove fuel rail and fuel injectors. See 4.12 FUEL
INJECTORS. This will allow access to the two screws that
secure the induction module to the intake manifold.
4. See Figure 4-40. Remove two screws (2) and separate
induction module from intake manifold. See 4.7 INDUCTION
MODULE.
5. See Figure 4-41. Pull induction module away from intake
manifold far enough so that TMAP sensor retaining bracket
(1) clears TMAP sensor body (2).
6. Unplug harness connector [80B] from TMAP connector
[80A] (3).
7. Grasp TMAP sensor and with a gentle twisting motion,
pull sensor straight up out of intake manifold body.
I would suspect that having removed the manifold with induction module the screws you are referring will be easy to get at.
Old Jul 26, 2020 | 02:48 PM
b0fh's Avatar
b0fh
i'd rather remove it without yanking the whole TBI out, but it's tricky. did that twice on my 2008, darn little sensor.
Old Jul 26, 2020 | 08:09 PM
iamjacks12's Avatar
iamjacks12
Stage III
Default 2nd update
I'm an idiot...
First. The no RSP code I got was caused by run switch off. Easy correction. No longer have any code issues.
TMAP that was pulled out was definitely damaged and rusted. So the replacement was warranted. I pulled the manifold off and made things much easier for the switch.
Now the bike won't start. I am wondering if something went sideways when I pulled the injectors. I checked and rechecked all the connections both on the electronics and the fuel line. Could the ECM not be recognizing the new TMAP?
Old Jul 27, 2020 | 02:47 AM
Andy from Sandy
The 2008 Electrical Diagnostic Manual suggests the TMAP sensor can be changed and it should work straight away.
What HD has is a set of breakout boxes that allows for voltages and resistances to be checked with everything plugged in. Probably very costly for a DIYer. You might be able to use a pin or similar to go in at the back of a connector to check to make checks.
Landon Martin
Oct 11, 2019 11:01 AM
LonewolfFrank
Nov 15, 2015 08:00 PM
AGWalker
Jun 15, 2014 12:12 PM
tombeving
Jun 26, 2012 11:56 AM
Tropical Andy
May 13, 2008 04:06 PM
