xl1200t fuel tank removal
Old Sep 21, 2020 | 11:14 AM
eggar's Avatar
eggar
Default xl1200t fuel tank removal
Hi, are there any threads that give instructions on how to remove the fuel tank on a xl1200t superlow, thanks
Old Sep 21, 2020 | 11:44 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Probably best to get a manual.
What year is your bike? What are you wanting to do?
Depending on year depends on how to purge fuel supply line.
Old Sep 21, 2020 | 12:31 PM
Andy from Sandy
Just seen your other thread - 2017.
Remove left side cover.
Remove ECM caddy cover.
Unplug the grey 4-way Molex connector that you should be able to trace back to the fuel pump.
Start the engine.
Operate the starter for a few seconds after engine stalls.
Remove main fuse.
Disconnect fuel supply line from tank.
Disconnect the vent pipe from the tank.
Remove the seat.
Remove the front and rear bolts that hold the tank on.
Protect top yoke and paint.
Lift rear of tank.
Remove fuel pump harness from trough on electrical caddy.
Remove fuel pump harness from caddy clip around frame backbone.
Protect the paintwork and you should be able to lift the tank off.
Old Sep 21, 2020 | 02:06 PM
eggar's Avatar
eggar
Hi, thanks for that, why do you have to purge the fuel line, can't you just disconnect everything and remove the tank, the reason i want to remove the tank is to inspect the welds on the inside of the mounting bracket where it runs along the tank tunnel, there has to be a simple reason why the tank is creating so much noise, cheers
Old Sep 21, 2020 | 03:18 PM
Andy from Sandy
It is under pressure and is liable to spray some petrol. You can just disconnect it or you can follow what is written in the FSM.
Old Sep 22, 2020 | 02:18 AM
eggar's Avatar
eggar
thanks, makes sense now, also is there a fuel tap or do you have to drain the tank completely
Old Sep 22, 2020 | 02:32 AM
Andy from Sandy
The connection is a valve, as you remove the fuel pipe so the valve closes in the tank. No need to drain the tank.
Old Sep 22, 2020 | 11:04 AM
eggar's Avatar
eggar
thanks !
cwsharp
2014-2024 Touring Models
Mar 29, 2019 02:08 PM
cwsharp
Mar 29, 2019 02:07 PM
mlrailguy
Feb 6, 2015 01:30 PM
Rev00
Oct 30, 2007 02:57 PM
Johneb48
Exhaust System Topics
Oct 19, 2005 09:40 AM
