Throttle cable change question
Old Feb 9, 2022 | 07:26 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
The “pull” cable is a little bit better this time
Both cables pull.
Old Feb 9, 2022 | 07:28 AM
AndyGats's Avatar
AndyGats
6th Gear
Thanks Andy from Sandy. That’s good to know. Think I may even carry a spare on longer ride. I came across 2 riders by the roadside last year with broken throttle cable and neither had anything to attempt a fix. One on an HD, the other on a KTM 690.
Old Feb 9, 2022 | 11:06 AM
Rob Roy's Revenge's Avatar
Rob Roy's Revenge
In 1984, I was riding southwards on the M6 on my Laverda 1200, just north of Knutsford services my throttle cable snapped off the nipple in the grip. I had a couple of Jubilee clips with my tool kit under the seat. I pulled off the upper outer sleeve down to the adjuster to reveal the inner cable, I them held the lower sleeve to the handle bar with one clip and the inner cable to the thottle grip with the other clip. I managed to ride another 70 miles down the motorway to my destination using that setup. I ordered a new cable from the Laverda importer for a proper fix.
Laverda's were notorious for having heavy controls that destroyed cables, I eventually cable tied a new cable to the throttle and clutch ones that I was using, if one snapped I'sd just disconnect it and connect the new cable. That was a trick that I learned to do when I owned a Triumph T140E Bonneville, it used to eat cables too. I think they used to call it character in those good old days, it was before teflon lined cables became widely available.
Old Feb 9, 2022 | 11:32 AM
AndyGats's Avatar
AndyGats
6th Gear
Amazing what can be done with a bit of ingenuity eh? I remember going for a test ride on a Jota sometime back in the 80s and the heavy clutch really put me off but I nearly bought it anyway just for that exhaust note. Pure Italian magic.
Andy
Old Feb 9, 2022 | 12:32 PM
Rob Roy's Revenge
Andy
Thanks for your reply Andy,
Aye, you need forearms like Popeye to ride the old Laverda's, they were also very tall and top heavy, I had the seat on mine re-upholstered and the seat hight was 33". I'm only 5' 8" with a 29" inseam, I had trouple putting my feet on terra firma so it was time to get rid of the Lavvy. It was very thirsty too, riding around town only gave 27 mpg and cruising returned 30 mpg. The pumper Dell Orto carbs gave instant accelleration through the rev range, first gear was very tall, I once had it up to 90 mph in first, but it was well into the red zone, fifth gear was an overdrive with a top speed of around 145 mph due to the Jota cams, high compression pistons and Jota big bore collector box and straight through Jota silencers bellowing that 180 degree exhaust note. It was alsolutely wonderfull to own and ride, it's faults were so few easy to forgive.
I traded the Laverda in against a Benelli Sei Mk2 in 1986 with a Ł150 refund due to the Laverda being worth more than the Benelli at that time, I still own the Benelli to this day, I've customised it over the years, a bank of six 22mm Dell Orto carbs with alumonium velocity stacks, Tomaselli quick action throttle, Paulo Tarozzi rearsets and a six into six Silentium exhaust system. It returns 45 mpg which I consider good for a machine with six carbs.
Are you regretting not buying that Jota?
Old Feb 11, 2022 | 01:22 AM
AndyGats's Avatar
AndyGats
6th Gear
No not really - I always go with gut instinct buying bikes and not pandering to current fads/trends. If it doesn’t feel quite right on a test ride, it probably isn’t the one for me. If I remember correctly I went for a Suzi GS1000S instead of the Jota. Okay maybe nothing like the character but so easy to live with and, probably more importantly, my missus liked it. That Sei sounds amazing - pure Italian engineering. Cheers Andy
nashvegasmatt
Feb 20, 2015 01:18 PM
apetterez
Jan 21, 2015 06:50 AM
scooper321
Apr 22, 2014 07:59 PM
firegrizz7
Mar 24, 2013 11:37 AM
superjohn148
Jan 13, 2010 07:04 PM
