09 1200c Front Conversion
Old Jan 12, 2024 | 02:27 PM
Rob Roy's Revenge's Avatar
Rob Roy's Revenge
Originally Posted by hammer6315
Talking wheel swapping: Is a 2008 Sportster rear disc wheel an easy swap with a 2005 Sportster rear laced wheel? Axel diameter & spacers the same? Thank you!
The rear axle diameter for 2005 to 2007 is 1".
The diameter changed to 25mm for the 2008 model year, it stayed at 25mm until the end of the XL Sportster line in 2022.
Old Jan 12, 2024 | 04:54 PM
Harley_ish's Avatar
Harley_ish
Didn't you previously ask that question? ... rear wheel differences
Old Jan 23, 2024 | 05:25 PM
Owner's Avatar
Owner
swapping front ends is easy as…?
I have Street Bob forks (49mm) Fat Bob fender (cut/welded to fit), 16 x3 sporty rim, 2018 Sportster 48 triple tree with Speed Kings upper clamp to allow install of my risers.
Only real issue was wheel spacers. I ended up buying a spacer kit from eBay and machining a couple, the sizes I needed.
You DON’T need to spend a huge chunk, if you search for alternate parts, NOT labeled “Sportster”. 👍
mediasony
Wheels/Tires
Jun 9, 2023 02:34 AM
Navigator33455
May 13, 2022 09:48 AM
XX25
Jan 6, 2015 02:44 PM
Gwaxley
Jan 5, 2015 01:54 PM
Gwaxley
Nov 28, 2014 11:30 AM
