Easiest way is to just get the pipes hot and scrape it off with your thumbnail....CAREFULLY..... Then use a little Flitz metal polish (after pipes cool down). I have used this method several times with no scratching or dulling... Yes, you may burn your thumb...... But I never have
you burnt your foot on the muffler? I can rest my foot on it and ive never had my boot melt. in fact mine dont seem to get that hot, i can rest my skin on it for awhile before i start to feel it.
easy off oven cleaner, it just sounds like it will do exactly what you need it to.
How long was your bike running for? Mine will get blazing hot!!!
They say to heat the pipes up a bit, spray the easy off on a towel not directly on the bike, and wipe off the stuff on the pipe. I have not had this problem but good luck.
hours. i actually just got back a few minutes ago and got off the wrong side of the bike and had my leg resting on the pipe for a bit before i noticed. got off the wrong side becuase a car pulled in too close to my left. thought i would clarify so i dont get crap about it hahahaha
If your pipes dont get hot you should take it to MOCO and let them study it, since its the only Harley in the world like that it should be worth a lot of money.
ORIGINAL: JosephGarcia
ORIGINAL: MJK
