Warranty issues
Old Jan 12, 2006 | 01:41 PM
AZFlyingDiver's Avatar
AZFlyingDiver
Default RE: Warranty issues
ORIGINAL: TCSTD
ORIGINAL: 30jim
If I do a stage 1 on my 05 1200 will it void my warranty?
NO, it will not void the warrantee. If you do a mod an IT causes a system or part of your engine/bike to need warrantee work, THEN they will have to proove that the work you did caused the damage to not be elligable for warrantee work. If you were to run lean and burn a valve or piston, THEN you voided the warrantee by what you did on that part only. If you add the stage 1 to your bike, you need to richen up the mixture whether it be carbed or FI.(in your case carbed)
Read these topics
https://www.hdforums.com/m_85511/tm.htm
https://www.hdforums.com/m_76699/tm.htm
What he said :-) A dealer may try to avoid warranty work, but be insistent - it's your right! Service-oriented dealers won't give you any problems at all.
Also, the service manual even implicitly recognizes that work will be done by parties other than the dealer (why even sell service manuals, right?) - and recommends that work be done by a knowledgeable person with the right tools.
Do the Stage 1, always keep receipts and records for work you do, and you'll be covered.
Good luck!
Tooth
Feb 6, 2013 04:08 PM
John_HD
Apr 25, 2012 11:15 AM
electaRICK
Sep 13, 2008 02:20 PM
davisrf
Aug 23, 2007 05:37 PM
CSI
Aug 3, 2007 07:59 PM
