screaming eagle ignigtion module?
Old Feb 8, 2008 | 04:48 PM
seven7's Avatar
seven7
Default screaming eagle ignigtion module?
stupid ? but what does it do and do i need it? saw one pretty cheap on e- bay.
[IMG]local://upfiles/19758/B25A6D5B1BA345098311269CC66B0B5E.jpg[/IMG]
Old Feb 8, 2008 | 04:50 PM
Booey424's Avatar
Booey424
Default RE: screaming eagle ignigtion module?
It will increase your top end rpm's.It doesn't do much other than that.You don't really need it,but I have one
Old Feb 8, 2008 | 05:45 PM
Lickety Split's Avatar
Lickety Split
Don't know much about that ignition module but you bike sure is sweet lookin.
Old Feb 8, 2008 | 06:46 PM
GothMetalGuitarist's Avatar
GothMetalGuitarist
The SE ignition is great for 883-1200 and up conversions. With the 883 ratio'd final drive, the extra torque from the 1200 conversion, and the added 500 rpms equals kick ***!!
Old Feb 8, 2008 | 07:01 PM
x2lee's Avatar
x2lee
IMO, the best MOD you can make on a harley engine is a *SE ignition module.
A stock ignitionmakes forhard starting, poor low end response, back firing and excessive vibration from the motor.
The stock Harley ignition is an EPA guysdream. Harley put it on to make these guys happy.For a rider tho, its junk. The SE ignition module just plugs in. It costs about $100 and will fix all of the above listed problems plus you can rev it around 1000 rpms higher. For another $50, you can get the SE coils. These are not all that unless you'regonna to run your engine above 5,000 rpm very often (I have them and I do)...
*or better than like maybe say a Crane ...
ORIGINAL: seven7
Old Feb 8, 2008 | 08:04 PM
aceospades's Avatar
aceospades
ORIGINAL: x2lee
ORIGINAL: seven7
from what ive read the coils are for the 03 and under models..you recommended them to me before and i looked them up and couldnt find the..someone told me that on the 03 and under it was a change that had to be done if you did the screamin eagle module due to some resistace thing in the stock coils..i did do the screamin eagle wires and plugs a while back,and did notice a great difference with the ignition module(almost scary) best 120 bucks i ever laid out on my bike(besides the big city thunder baffles) if you decide to get it you will be happy...
Old Feb 8, 2008 | 09:47 PM
x2lee's Avatar
x2lee
you know, I have an 03 and I always seem to think in terms of my bike...
sorry about that, but the ign is still money well spent like you said..
ORIGINAL: aceospades
ORIGINAL: x2lee
ORIGINAL: seven7
Old Feb 8, 2008 | 09:50 PM
GothMetalGuitarist
I agree with both AOS and X2lee.
Old Feb 8, 2008 | 09:56 PM
Biker Trash's Avatar
Biker Trash
I saw that one on ebay too. It was for an 03 and older and I thought about picking it up. unfortunately I won't have internet service till Wed after tonight due to moving so I can't watch it. [:@]
I sure wouldn't mind getting one and the coil as well. I probably won't worry too much till I get cams.
Old Feb 8, 2008 | 11:33 PM
danmo's Avatar
danmo
I've been considering installing the SE Coil, Wires and ignition but didn't know if it was worth it. Probably my next investment now.
