'07 1200 custom gas tank strip removal
Old Mar 23, 2008 | 11:54 PM
YodaddyKeith's Avatar
YodaddyKeith
Default '07 1200 custom gas tank strip removal
Gents,
Let's say a guy wanted to remove the stainless strip on his custom modelgas tank.....What's the procedure and what can he expect to see once it's off?....Is the tank painted beneath it, or will it leave an ugly stripe?
Thanks for you answers
Old Mar 24, 2008 | 12:16 AM
6o66er's Avatar
6o66er
Default RE: '07 1200 custom gas tank strip removal
I believe it's just glued on...so use a heat gun and some fishing line or somethin...should be painted underneath, too.
Old Mar 24, 2008 | 09:30 AM
nazareth27's Avatar
nazareth27
I took mine off on my custom. Just get some dental floss, rip a long, long piece, and then double braid it and holding it, work it back and forth as you move along under the strip, it will cut through two strips of glue tape adhesive. Take your strip off, and then use a little pb decal remover OR pb blaster, to gently remove the leftover glue adhesive (I rubbed lightly with a fingernail and an old sockand it all came off finally) . I was really happy with the result, I wondered the same thing for a long time if the tank was all one piece. I replaced my gas cap with a flush mount pop-up after that, and learned how to do all this right here on the forum. Was a fun mod and really good result.
Old Mar 24, 2008 | 11:20 AM
YodaddyKeith
Thanks Naz....gonna do it right now....I've removed plenty of glue/foam before so I know what to expect there...Yuck!
Old Mar 24, 2008 | 11:41 AM
Mykey's Avatar
Mykey
I recently added a tank trim panel to my bike.The installation instructions included the procedure for removing the old trim panel.HD says to use the fishing line method then remove as much adhesive with your fingers as possible.Clean tank surface with a mixture of 50 to 70% isopropyl alcohol and 30 to 50% distilled water.
Old Mar 24, 2008 | 11:46 AM
YodaddyKeith
20 minutes later(including time it took to borrow roll of floss), it's done!
Paint looks perfect! I agree it's a big improvement....now theres acres of room for special paint graphics.
Thanks Naz!
Old Mar 24, 2008 | 01:45 PM
nazareth27's Avatar
nazareth27
yer welcome yo!
Old Mar 24, 2008 | 01:48 PM
YodaddyKeith
Go here to check out results of your advice
https://www.hdforums.com/m_3087952/tm.htm
Ayelith
Mar 22, 2014 09:47 AM
JPL
Oct 5, 2011 02:15 PM
Kodster
Apr 18, 2008 03:51 PM
russellabjr
May 29, 2007 04:13 PM
wwgilstrap
Oct 10, 2006 07:30 PM
