Weak Battery
Old Apr 14, 2008 | 02:34 PM
SpursDarkrider's Avatar
SpursDarkrider
Default Weak Battery
Got up this morning and was gonna ride my bike to work and the battery was weak and wasnt enough juice to fire up the bike. The lights came on and the starter turned slowly but wouldnt fire it up. Came home and hooked up the battery charger/float tender and checked the positive cable. Seems to be tight. Anything else i should check? Its an 07 1200 custom-stock.
Old Apr 14, 2008 | 02:45 PM
wdg's Avatar
wdg
Default RE: Weak Battery
get a battery tender
Old Apr 14, 2008 | 02:48 PM
SpursDarkrider
So what your suggesting is that i plug in the battery tender all the time when its parked overnight?
Old Apr 14, 2008 | 03:02 PM
nazareth27's Avatar
nazareth27
i have a black and decker automatic charger, I actually carry it with me all the time, its small enough to go in my saddlebag and does a good job,its not a trickle charger, but id love havin the tender.
Old Apr 14, 2008 | 03:41 PM
cHarley's Avatar
cHarley
ORIGINAL: wdg
Why, he said he had one and hooked it up.
Did you check both ends of the Neg. Battery cable as well?
Old Apr 14, 2008 | 03:53 PM
rnl_1200C's Avatar
rnl_1200C
Do you have the factory security system activated ? It will put a heavy drain on the battery.
I also use the 1.25Amp battery tender rather than the .75Amp - much better, and will charge the battery much faster.
Old Apr 14, 2008 | 04:28 PM
SpursDarkrider
Ok will check the ground cable. I have a Schumacher 1.5 amp slow charge battery charger maintainer with float mode monitoring. Is that the tender you guys are talking about?
Old Apr 14, 2008 | 05:20 PM
cHarley's Avatar
cHarley
ORIGINAL: SpursDarkrider
Yes, that's fine.
Old Apr 14, 2008 | 07:42 PM
SpursDarkrider
Ok i checked to see if the bike would start after about 4 hours on the charger/tender and it fired right up. I am gonna keep it charging till the charged light comes on. I checked the negative cable and its tight. Im wondering if sitting in stop and go traffic for 1 1/2 hours last friday may have drained down the battery? The only riding i did saturday and sunday was short hops to and from the store.
bigjosh42
Electrical/Lighting/Alarm
17
Feb 8, 2019 12:52 AM
DeeRides
Dec 18, 2013 09:54 AM
woodwarda99
16
Nov 7, 2013 08:30 AM
CWDoc115
Aug 21, 2011 09:59 PM
Danall
Oct 29, 2007 05:01 PM
