charging system question
Old Apr 17, 2008 | 08:56 AM
GBS Customs's Avatar
GBS Customs
6th Gear
Default charging system question
OK my charging system is a bit screwy. i don't know alot about bike so here it goes.
with light off i get 13.5+ volts with a moderate RPM level and 12.3 at idle. i was told the stater or stator needs to be replaced. i know it is under the primary cover but how much and where can i get one with out having to go through HD. i like JPCycles.com as i have got alot through them. any one have a part #? Price? and can i change it on my own? i'm sure i'll need a new gasket as well so part #'s would help on that as well.
Bike: HD Sportster 883 worked over to a 1340
Year: 1988
Thanks
Rick C
www.gbscustoms.com
Old Apr 17, 2008 | 09:03 AM
DeJavu's Avatar
DeJavu
Default RE: charging system question
It's possible on any Harley to set the idle so low that the alternator drops to 12v output. Try raising the idle a little and see if the volts don"t jump up to 13.5v. If you like the Potato/potato idle, just be aware you are probably not charging.
Old Apr 17, 2008 | 09:16 AM
GBS Customs
6th Gear
nope it is not charging to the fullest that it should. if i ride around town (Cruising with moderate rpms) with the light on like by law it will be hard to start if at all. if i shut it off then it's is fine. almost like the generators use to do with worn or bad brushes.
Old Apr 17, 2008 | 09:39 AM
DeJavu's Avatar
DeJavu
You don't say what yr/model you have. The older 22 amp stators may not put out enough if you have a high watt bulb in your headlight. Newer models have a 32 amp stator. Like you say, it just might be a bad stator. Not hard to replace, pull primary cover, remove engine sprocket/pulley, remove rotor(use puller or bolts as handholds), it is magnetic and requires effort to remove. You can then disconnect stator plug and small stator retaining screws and remove stator(might be tough to pull also, press fit).
Reverse order for assembly. A manual would be helpful. Good Luck.
Old Apr 17, 2008 | 09:50 AM
85green's Avatar
85green
Just last night I was reading in American Iron magazine about the charging system. Explains the theory of operation and how to test. Might be worh looking at. I am not promoting the mag but is was interesting.
Old Apr 17, 2008 | 12:45 PM
cam it!'s Avatar
cam it!
Test the voltage regulator before you do the stator job....I'm told that when they go bad they just stop putting out voltage but had one two years ago that put out too low a voltage. Changed that instead of the stator...still charging fine.
Rick C.
Old Apr 17, 2008 | 01:11 PM
DeJavu's Avatar
DeJavu
The regulator most often fails and allows an overvoltage situation(16+v) which fries batteries. Was not aware that failure could produce too little voltage, that is normally a stator problem.
Old Apr 18, 2008 | 05:23 AM
cam it!'s Avatar
cam it!
Yep...that's exactly how it was explained to me...overvoltage...but somehow ( and I don't pretend to know why) I couldn't get more than 11.5 volts out of mine at any rpm and changing to a new regulator I get up to 14.5...
Rick C.
Old Apr 18, 2008 | 08:10 AM
DeJavu's Avatar
DeJavu
ORIGINAL: cam it!
Rick C.
If the diodes are blown = overvoltage, if regulator is fried = no charge(also can be fried or bad connection to stator)
JonnyVegas
Oct 25, 2017 07:27 PM
hellmut73
Feb 12, 2016 12:17 PM
majpaine
EVO
Jul 18, 2014 01:43 PM
Kentucky Colonel
Sep 30, 2012 10:53 AM
jacknthebox
Aug 2, 2010 09:53 AM
