Can anyone tell me if your rear fender is closer to one side of your tire than the other. Mine is closer to the right side quite a bit. I want to lower my rear end and I am afraid that I will rub on the side of the tire not the top like most riders would worry about.
Your bike is normal all older Sportster have the wheel offset in the fender, you especially notice it when youstuff a 150 tire in those older fenders. It's always a little tighter on the LH side.
I don't know if the newer bikes are like this or not.
Yep, mine is closer on the right side too.However, you can't tell by looking, but just by feel of the gap between the inner fender bolts/nuts & the tire. Oh, and I slammed the rear of my sporty down further than most...10" shocks.
I didnt know that about the older bikes, newer EFI models dont seem to have that, least i never really noticed.
On most, you will not notice. Mine you can only tell by sticking your fingers up under the fender in-between the tire and fender mount/strut bolts. I think it's like a 1/8" on the right & a 1/4" on the left side. Check yours.
Thanks everyone, WVHogRider, can I assume that when you slammed your rear end you didn't rub on the RH side. I am considering replacing the shocks with 10" struts to make it a Hardtail.
No, I didn't rub on the side nor on top....However, you do need to make sure the seat bolts aren't too long. Loneryder's seat bolt(s) were to long and he shreaded a tire. I had just enough clearance all around.
