Drain Plug
Old Jul 14, 2008 | 09:28 PM
AK_1200C's Avatar
AK_1200C
6th Gear
Default Drain Plug
I just changed the fluid in the transmission and I seem to have a leak somewhere.&nbsp\\; I was wondering if the drain plug needs anything on the threads or if there is a washer of some sort that the manual does not talk about?&nbsp\\; The bike is a 2006 1200C and I have looked in the manual, but couldn't find anything.
Old Jul 14, 2008 | 09:41 PM
DPete's Avatar
DPete
Default RE: Drain Plug
There should be an O-ring on the plug. There is on my 07
Old Jul 15, 2008 | 01:01 AM
HDXXX's Avatar
HDXXX
You could put a little pipe thread tape around it.
Old Jul 15, 2008 | 01:35 AM
lostrider06's Avatar
lostrider06
If you over tighten the drain plug it will crack the case were the plug screws in. Ask me how i know this lol. Thats what happen to me anyway but i went an got some high temp silicone an put on it were it cracked an it stopped my leak. hopfully yours is not cracked might want to change it again an put a new o ring on it an maybe some pipe tape to. good luck either way&nbsp\\; &nbsp\\; &nbsp\\; &nbsp\\;
Old Jul 15, 2008 | 07:58 AM
carlo's Avatar
carlo
Were did u add the new trans fuild. Derby cover' or primmery insp cover. mine leaks a little from inspection cover on long rides. Im not the only one this happened to was a post on the insp cover weeping fuild. I put a little silicone on the screws it helped. My bike is a 06-1200C
Old Jul 16, 2008 | 03:48 PM
AK_1200C's Avatar
AK_1200C
6th Gear
Thanks for all of the responses.&nbsp\\; I checked the manual again and it does not mention an O ring.&nbsp\\; It had a leak already that now seems to be worse, so I took it into the shop.&nbsp\\; They said that there is not an O ring on the 2006.&nbsp\\; Hopefully they can get me on the right track. Once again, I appreciate the help.
Neopheous
Mar 13, 2025 03:50 AM
stal94gt
Feb 9, 2016 05:27 AM
Wishbone68
Jun 30, 2014 04:40 PM
BigFatHawg
May 10, 2010 06:18 AM
2008FLHP
Jun 18, 2008 08:08 AM
