Oil Spray ??
Old Aug 24, 2008 | 04:20 PM
cHarley's Avatar
cHarley
This is one example of an oil bypass, there are several different units available. It does solve the problem.
Old Aug 24, 2008 | 04:26 PM
racinorange's Avatar
racinorange
yours is prettier than mine....
how did you post that pic? I can't figure out how to do that?
Old Aug 24, 2008 | 05:37 PM
HernD's Avatar
HernD
6th Gear
Thanks guys, some interesting and useful info there.
New to Harleys, and it's fun getting to know them isn't it?
As it seems a minor problem for now, just a quick wipe clears it off where its landing, and definately no puddles on my garage floor, I'll just endeavor to keep it clean.
But, two things. Is it likely to become worse, just a symptom of hard riding, and I am thinking of having a Forcewinder AC fitted will this eradicate this minor prob?
Thanks
HernD
Old Aug 24, 2008 | 06:20 PM
racinorange
If you want to solve this problem, DO NOT GET A FORCEWINDER, I have one, which why I had to run the 'rig". The forcewinder runs the breather hose into the filter element, which causes the oil to collect and come out much worse! I ruined every pair of khakes I own! Plus the forcewinder is robbing me of horse power so says my tech. And it won't get worse as time goes on btw.
Old Aug 24, 2008 | 06:33 PM
Wecroft's Avatar
Wecroft
Here's the solution to your problem
http://www.dragspecialties.com/fatbo...ather%20bypass
Old Aug 24, 2008 | 07:26 PM
128auto's Avatar
128auto
Old Aug 24, 2008 | 07:45 PM
Dorkman's Avatar
Dorkman
Before you do any mods, try filling the oil tank no farther than half way between the two lines on the dipstick, measured hot. Common problem.
Old Aug 24, 2008 | 08:53 PM
trailey97's Avatar
trailey97
heres another question for ya and im not tryin to steal this thread...
this whole oil issue is actually causing me some big problems cause im havin to add oil just with in two or so days of ridin just to and from work and i only work 70miles from home but dont have to go everyday.. also noticed that by the time i get close to work and i stop and then go... my trans starts to squeak, it sounds like a rusty bolt being untightened. is this all this because of the oil im losin.. im runnin amsoil in it.
if you have a puddle under the bike after you park it? then how ofen are you havin to add oil and why cant there be a way to fix it to where you dont lose any oil.
mines been at the stealer 3 times and they cant even fix it and neither can a local shop. WTF
96CubicPair
Jul 27, 2015 12:40 PM
mikeallenbrown
Aug 27, 2011 12:02 PM
coorsbig8balls
Mar 20, 2011 09:57 PM
rich624
Oil Archive (no new posts)
May 10, 2009 11:09 PM
renegadewheelman
Sep 10, 2007 04:17 AM
