Two Questions
Old Oct 4, 2008 | 09:19 AM
Tropical Andy's Avatar
Tropical Andy
Default Two Questions
Question one: Is there a centre stand (bolt on fixed type) available for a Sportster? Mine's an 883L (2005)
and Question two: I have just bought one of the Extreme digital battery tender/chargers (works great by the way, so far I've tried it with the battery removed from the bike) this came with a harness so the battery can be charged while still in the bike. Now with all the electrioics on the bike is it OK to charge the battery without disconnecting anything or should the main fuse be removed (while charging)?
Any advise would be appreciated.
Old Oct 4, 2008 | 09:32 AM
skydoc's Avatar
skydoc
1. no
2. yes (no need to remove fuse)
Old Oct 4, 2008 | 09:33 AM
cHarley's Avatar
cHarley
I think I recall seeing an aftermarket center stand but ground clearance can be an issue. The bike frame is already pretty low to the ground on an L model.
No, you don't need to disconnect anything to charge the battery while it's in the bike. That's the normal way most of us do it. Just mount that little harness that came with the charger to the battery terminals and your all set.
Old Oct 4, 2008 | 09:40 AM
Tropical Andy
Many Thanks.
I may try and fabricate a stand or modify an aftermarket stand, I'll let you know how it goes.
Andy
Old Oct 4, 2008 | 11:14 AM
JosephGarcia's Avatar
JosephGarcia
its for 1957 to 1981 sportsters only.. bolts right on to stock frame points.
Old Oct 4, 2008 | 04:37 PM
schumacher's Avatar
schumacher
1) steel milk crate
2) just hook it up
Old Dec 22, 2008 | 09:49 PM
Ken McGough's Avatar
Ken McGough
3rd Gear
My dealer added a battery tender for $50 on my 2007 low without asking me and I told him I'd ask first if I wanted to buy one. I just found out today 1 1/2 years later that they automatically add a pigtail for connecting the charger and if you opt out they remove your seat and remove the pigtail. What a bunch of Dicks! Anybody else know about the pigtails or dealer practices concerning supplying them "automatically" without telling you about it? Is the pigtail a dealer or factory add on?
Old Dec 22, 2008 | 10:21 PM
Shadow_Demon's Avatar
Shadow_Demon
I haven't seen a center stand on a bike since I was a kid and I bought a Honda trail 50 from a fellow. I thought that stand was neat. As far as a battery tender. How long are you plannning on the bike sitting?
Old Dec 22, 2008 | 10:27 PM
Shadow_Demon
Wink
I'm the only battery tender my bike will know.
nasumi2002
Nov 4, 2010 10:10 AM
Supamag
Oct 11, 2010 06:04 AM
mke125125
Jan 17, 2010 12:10 AM
08HD
Jan 12, 2009 08:34 PM
TJ Willy
Jun 24, 2007 04:08 PM
