How does the coil mount on the side? Do you have to modify the coil or does it bolt right up? Can you use the same plug wires after re-routing? Or do you have to buy shorter ones.
you have to fab up a bracket. and i believe u would want to buy another short cable because one of the cables would be too long. there is another thread on the forums about this.
I bought 2 long plug wires, carefully took the end off the plug end of it and shortend them up. The factory short plug wire, is to short, and the long one is, well to long.
You have to fab a bracket. I make mine out of a Big Twin 96 air cleaner bracket. Fit perfect
