Replacing throttle cable help....
Old Mar 17, 2009 | 09:35 PM
JLuns's Avatar
JLuns
Default Replacing throttle cable help....
How in the world do you remove the throttle cable from the handle bar mount? I looked and played with that thing for about 30 minutes trying to figure it out. And how hard is it to replace the clutch cable? I already have it off the lever. THANKS
Old Mar 17, 2009 | 10:20 PM
SpursDarkrider's Avatar
SpursDarkrider
Your gonna hear this eventually, so i might as well tell you politely. A service manual is a must, well worth the money. Will answer all your questions. I would copy and paste to you from an 06 service manual, but i dont know if it will help. If you want it just PM me privately. The powers that be frown on bootlegging manuals.
Old Mar 17, 2009 | 10:31 PM
stng_96's Avatar
stng_96
To answer your question, you basically have to force it out. Whenever I worked at the factory in Kansas City, I was amazed to see that when cables would need to be changed, the mechanics would just have to set and work it out. I have done it as well, and believe you me, it is a HUGE PITA, but basically you just have to pull really hard and work it out.
Old Mar 17, 2009 | 10:40 PM
HOTLAP's Avatar
HOTLAP
I haven't changed the cables but did take apart my control when I changed the bars. Just remove the screws that join the upper and lower half of your control and gently seperate them, beware...there are some bits in there that will fly out if your not careful, once you get those out of the way it will be obvious how to slide the cable out of the housing.
Then just put it back together the way it was, again, I can't stress the importance of carefully removing everything and noting where all the bits fit in as your taking it apart so you know where they fit back in when putting it back together.
Hope this helps, at least until you get a manual.
Old Mar 18, 2009 | 07:15 AM
olpet's Avatar
olpet
4th Gear
Default Cables
Loosen the tensioning nut all the way on the cable. Open the clamp, remove the ferrule from the slot in the grip. If yours has a nut on the cable hardware where it enters the clamp loosen it and pop the cable out. If it doesn't have the nut just pop it out, force it it will come.
Old Oct 10, 2012 | 10:40 PM
Serena Ryder's Avatar
Serena Ryder
Stage I
thanks i got it . iam out of clutch cable adjustment so does someone know how to adjust the main drive clutch on the motor on the 98 HD?
dhonn7
May 17, 2013 01:54 PM
TSD
Apr 29, 2012 08:26 AM
msamarah86
Jun 22, 2011 07:34 AM
YmeHP
Sep 4, 2009 09:50 AM
dgriffith
May 2, 2007 07:43 PM
