Enrichener Cable Problem
Old Jun 6, 2006 | 01:36 AM
WarriorHD's Avatar
WarriorHD
Default Enrichener Cable Problem
I think I've been struck by the notorious enrichener cable problem. When I pull the choke, it automatically snaps back in and will not stay open. I have to hold it out in order to start the bike. Has this happened to anyone else? What's the fix for it? It's under warranty but I'm curious as to why this happened. I didn't touch anything....lol....at least not this time.
Old Jun 6, 2006 | 02:04 AM
1200c's Avatar
1200c
Default RE: Enrichener Cable Problem
I had that happen to me. It was a bad enricher cable. I don't know the exact details, but I didn't care at that time. Just take it to the dealership and they will replace the cable under warranty. If they don't then it's a $14 part.
Old Jun 6, 2006 | 08:47 AM
whaap's Avatar
whaap
I've read that the nut behind the choke (enricher) lever is a tension adjuster. I haven't tried it as I don't have a problem but it might be worth it to grab a wrench and see.
Old Jun 6, 2006 | 09:27 AM
recross's Avatar
recross
Yup what WHAAP said...there is a tension nut on the back side of the bracket.....no real big deal to adjust..........
Old Jun 6, 2006 | 11:04 AM
12Stones's Avatar
12Stones
My brother had this problem also and the tension nut couldn't help. They had to replace the cable on his. Try the tension nut first and if that doesn't help, get it to the dealership since it should be covered by warranty.
Old Jun 6, 2006 | 01:02 PM
whaap's Avatar
whaap
I just went out and played with the enricher on my 05 1200 C. Forget the nut. Immediately behind the enricher **** is a knurled, round fitting. It almost looks like a very thick plastic washer only it is knurled. Turn that to the left to loosen tension. To the right to tighten tension.
Old Jun 6, 2006 | 01:09 PM
whaap's Avatar
whaap
I forgot to mention. No tools required. Just use your fingers.
Old Jun 6, 2006 | 09:18 PM
WarriorHD's Avatar
WarriorHD
OMG...What an easy fix! Duh, now I feel really stupid.
Whap...your finger solution worked like a charm! Thanks my brothas!
Old Jun 6, 2006 | 10:32 PM
whaap's Avatar
whaap
Hey, everything is simple once you know.
BobFLHT2002
Carburetor Related
Jun 7, 2018 08:03 AM
tOSUSteve
Aug 26, 2014 04:03 PM
trackadaptor
Aug 22, 2012 12:01 PM
5speedblu
Nov 26, 2008 05:20 AM
Booey424
Aug 28, 2007 05:01 PM
