Progressive 440s
Old May 9, 2010 | 05:10 PM
scrunchee's Avatar
scrunchee
Default Progressive 440s
I just finished installing a new pair of Progressive 440 rear shocks. I installed the left side first with no problems. When I installed the right side, I had to jack the bike up a little bit to get it on. I was following my manual and it says I didn't need to jack up the bike as long as the other shock was still on. Also, the instructions that came with the Progressive shocks states I need to use the #1 spacer and #4 spacer for each bolt. I installed as instructed and everything looks fine. I haven't gone for a test ride yet but I just wanted to make sure that everything I did and used is correct. Thanks for any info.
Old May 9, 2010 | 05:30 PM
1200Cdriver's Avatar
1200Cdriver
What length did you put on, just curious. To answer your question, it sounds like you did everything correctly. I had to put a thin washer between the right inside spacer and the belt guard mount. The bottom of the shock rubbed the guard bracket, but just barely, yours may not.
Old May 9, 2010 | 05:32 PM
Tike71's Avatar
Tike71
If the shock doesn't obstruct anything (ie beltguard) and you have the bolts torqued to the recommended specs then you're good. Go for a ride!
Old May 9, 2010 | 05:54 PM
scrunchee's Avatar
scrunchee
I have the 11.5" shocks. I did triple check everything and I don't see any obstructions. I did torque the bolts to proper specs. Unfortunately, it is raining by me right now, so I have to postpone the test ride. Thanks for the reponses. Very much appreciated
Old May 9, 2010 | 06:04 PM
1200Cdriver
Here is a shot of the washer, I put one at the top too so the shock would not be out of line. I have 13.5" 440 srandards with LAChoppers 1" lowering blocks to gain suspension travel but not too much heighth. It worked to perfection, I run Progressive fork springs with BelRay 7w oil.
Old May 10, 2010 | 10:13 AM
scrunchee's Avatar
scrunchee
Thanks for the pic, 1200 C Driver. Mine clears the belt guard with the spacers Progressive instructed to use. I didn't need to add another washer. I'm going to test ride my bike later today after work.
Old May 10, 2010 | 09:07 PM
lilbruce's Avatar
lilbruce
How much do these shocks cost?
Old May 10, 2010 | 09:31 PM
1200Cdriver
My 13.5" 440s were $544 and free shipping, the current price for 11.5" 440s is here.
http://www.denniskirk.com/jsp/tpl/pr...&mmyId=9700033
Old May 10, 2010 | 09:49 PM
lilbruce's Avatar
lilbruce
Thank you!
Old May 11, 2010 | 05:57 AM
scrunchee's Avatar
scrunchee
I bought mine for $476.95 from www.onestopmoto.com. They shipped pretty quick too.
steveket
Jul 14, 2019 07:11 AM
Agiuliano10
Jul 7, 2013 12:53 PM
1sweetglide08
Jan 27, 2012 08:03 PM
jasononaharley
Apr 17, 2008 03:22 PM
dirt_dobber
Jun 15, 2006 12:30 AM
