What now !?!?!?
Old Jun 2, 2010 | 08:30 PM
arod6's Avatar
arod6
Default What now !?!?!?
Just got my Stator/Battery/Regulator replaced 500 miles ago on my 06 XLC. Everythings been fine, but after lunch today she wouldn't turn over - it seemed the more I tried the less responsive it got. Finally - just a bunch of clicking noises from the starter I guess, then just one click per press.
No diag codes are present - is this the Starter?
Any ideas or thoughts?
Old Jun 2, 2010 | 11:35 PM
woodworking1's Avatar
woodworking1
sounds like a dead battery. Was it trying to fire? Were the plugs getting spark? Is it getting gas?
Old Jun 2, 2010 | 11:54 PM
valacech's Avatar
valacech
Dead battery. Dead as a door nail.
Old Jun 3, 2010 | 12:31 AM
arod6's Avatar
arod6
Really? you guys think its a dead battery? wouldn't the check engine light come on if its a dead bat - the darn bat got replace 500miles ago.
Old Jun 3, 2010 | 02:53 AM
arod6's Avatar
arod6
I did make 3 short trips - off/on; this may very well be the bat. I'll give it a charge and see what happens.
Old Jun 3, 2010 | 08:37 AM
Hitechluddite's Avatar
Hitechluddite
Put a trickle charger on it overnight. And grab a DVM. Check the voltage before you turn off the trickle charger. You should have greater than 14V. Unhook the charger you should have around 12.6V let it set for an hour or so and it should still be around 12.6V start the bike at idle you should be around 13V with the meter still connected at idle hit the brake lights you should see a drop in the voltage then it should recover to near where it was with no brake lights.
That checks your battery, charging system and regulator, it does everything except load test your battery.
Old Jun 3, 2010 | 10:36 AM
WVHogRider's Avatar
WVHogRider
Also, check all four of the battery wire connections with a wrench to make sure they are still tight from when the battery was just replaced, as it could just be a loose cable.
Old Jun 3, 2010 | 11:59 AM
schumacher's Avatar
schumacher
^^^^^^what they said
Rusty Axle
Shovelhead
Apr 18, 2020 07:20 AM
cowpoke
Engine Mechanical Topics
May 14, 2014 08:19 AM
steelman
Feb 12, 2013 10:15 PM
Nautilus
EVO
16
Nov 10, 2010 07:28 AM
ae4782tt
Exhaust System Topics
Oct 4, 2010 12:39 AM
