Right Turn Indicator Doesn't Work?
Old Jun 28, 2010 | 06:38 AM
rg567's Avatar
rg567
Default Right Turn Indicator Doesn't Work?
2002 883R 7000mi
Both blinkers work fine but the right indicator light on the dash does not light up. I tried wiggling wires a little bit but thats about it. The book says there are no bulbs to change so I'm looking for advice.
Thanks in advance.
Old Jun 28, 2010 | 06:41 AM
xFreebirdx's Avatar
xFreebirdx
Make sure the 2 wires that slip into the rubber housing right behind the light are seated properly.
Old Jun 28, 2010 | 04:31 PM
woodworking1's Avatar
woodworking1
if that dosen't work, change the bulb.
Old Jun 28, 2010 | 06:48 PM
jag1886's Avatar
jag1886
I most certainly does take bulbs and the part# is 68024-94 indicator bulb uses 5. I don't know what book you are looking at but it's wrong.
Old Jun 28, 2010 | 07:03 PM
rg567's Avatar
rg567
The owners manual didn't list a bulb for it so I figured it was led or something. I'll check it out. I'm gonna feel dumb if there is a bulb and I didn't even look
Old Jun 29, 2010 | 07:29 PM
rg567's Avatar
rg567
Just an update. I am dumb, it does take bulbs. Problem was not a bulb, it was a loose bulb connection. Spread out the contacts on both the bulb and in the socket and applied a little dielectric grease and the indicator is working for the first time since I've owned the bike. Thanks all for the suggestions.
Old Jun 30, 2010 | 01:05 AM
testifer's Avatar
testifer
the older models dont take bulbs, have to change the whole assembly
Old Jun 30, 2010 | 06:38 AM
xFreebirdx's Avatar
xFreebirdx
roadkingdean
Electrical/Lighting/Alarm
Dec 23, 2015 10:13 AM
ryderbiker
Sep 21, 2015 04:12 PM
Mattyrattlesnake
Jul 22, 2013 05:53 PM
trikerbob2
Oct 17, 2009 01:17 PM
vet767
Mar 14, 2008 01:39 AM
