Riser bushings needed?
Old Jul 8, 2010 | 10:50 PM
ubiasylum's Avatar
ubiasylum
Default Riser bushings needed?
If I am going from the riser/speedo combo on the 06 Custom model, do I need to get a set of riser bushings?
Here is what I may get:
http://www.jpcycles.com/search/produ...il?sku=5000719
or
http://www.lickscycles.com/catalog/p...qr72b0md2ha3o5
Old Jul 9, 2010 | 08:49 AM
ubiasylum's Avatar
ubiasylum
anyone?
Old Jul 9, 2010 | 09:35 AM
3rdgear's Avatar
3rdgear
You should be able to use the bushings you already have..
the only thing I would be concerned with is what your going to do with all the wires that are in the original riser..
(Nice riser though)
Old Jul 9, 2010 | 11:30 AM
Somber Goat's Avatar
Somber Goat
+1
If you are swapping the bars as well its recommended by some to get new poly bushings.
Old Jul 9, 2010 | 11:33 AM
ubiasylum's Avatar
ubiasylum
I do plan on switching the bars... got some Lick's 12" Fatty Z bars. Thanks for the input.
Old Jul 9, 2010 | 01:17 PM
3rdgear's Avatar
3rdgear
NP.. and if you do decide to get some new bushings get some from JP.. here is what I paid there..
Merchandise Total : 11.99
Shipping / Handling : 7.99
Order Services : 0.00
HANDLING FEE : 1.75
Total Order Charges : 21.73
5000021 1 - 11.99
POLYURETH RISER BUSHING 4PK
But then again.. if they have them cheaper than $22 at the HD Stealer.. then I would just get them their and you don't have to worry about waiting on them to come in.
Old Jul 9, 2010 | 06:30 PM
HarleyScuba's Avatar
HarleyScuba
What da...?
I thought all Sportster handlebar risers were solid mounted since '04. Am I missing something?
I did see a write-up somewhere about what you need to do to graft a pre-'04 upper triple clamp onto an '04 and up so that the handlebars become rubber isolated (bushings). No idea where I came across that..
Old Jul 9, 2010 | 07:01 PM
1970FL's Avatar
1970FL
My 05 1200C has no bushings, solid mount.
Changed to an 03 straight riser and different speedo mount and it bolted right up.
The upper tree is not counterbored for bushings, unless the bushing kit is custom made for it to work with different risers.
Old Jul 9, 2010 | 07:13 PM
punkmxcn's Avatar
punkmxcn
All '04 later xl models: no bushings.
crawlgsx
May 8, 2016 09:05 PM
dtaylor00
Jun 3, 2013 01:46 AM
Madcitybiker
Mar 17, 2010 11:16 PM
will227457
Nov 5, 2009 08:52 AM
mcro
Jan 31, 2007 10:53 PM
