Oil temp dip stick problems
Old Jul 15, 2010 | 05:58 AM
HDJIM1158's Avatar
HDJIM1158
Default Oil temp dip stick problems
I have the HD oil temp dip stick on my 2004 1200 Custom. I am having a lot of problems getting it in a out, in fact so much I went back to the stock one, is this common or is there a fix ???
Thanks in advance for the Questions, I am new to the Sportster line.
Be Safe JIM
Old Jul 15, 2010 | 06:50 AM
DaytonaSportster's Avatar
DaytonaSportster
Is it that you cant grip it or it simply wont come out.
My neighabors bike is 10mths younger than mine by production code and our factory oil tank plugs are different. Mine has raised bumps to better help with grip and his is smooth.
I am ordering a temp stick and I told him I would give him my old one as the grips make it from damn hard to easy to get out.
His temp solution was to scuff up the finish with some sandpaper.
Old Jul 15, 2010 | 07:29 AM
cHarley's Avatar
cHarley
I've never had a problem with my analog oil temp dipstick, with over 60,000 miles on the bike. Is the O-ring in good shape?
Old Jul 15, 2010 | 09:53 AM
SportyPig's Avatar
SportyPig
I have the same problem with my oil temp dip stick.
Old Jul 15, 2010 | 02:06 PM
HOTLAP's Avatar
HOTLAP
My analog temp dip stick is a LOT easier than the pop up factory cap.
Old Jul 15, 2010 | 05:39 PM
turn8a's Avatar
turn8a
Was having the same problem ..Just replaced the o ring and it seems to work fine. I used the o ring from the stock oil cap.
Old Jul 16, 2010 | 12:10 PM
Notorious688's Avatar
Notorious688
No problems on my temp stick.
Old Jul 16, 2010 | 08:32 PM
Osco's Avatar
Osco
Account Deactivated
Cool There ya go
Smart move,,I will remember that...
Old Jul 17, 2010 | 04:55 AM
MechsHands's Avatar
MechsHands
You aren't trying to put it in incorrectly are you? There was a guy here having problems with his stock cap and didn't realize that there was a wide tang and slot and a narrow tang and slot. He was trying to put the wide tang into the narrow slot and it was jamming.
MH
W4MAC
Shovelhead
15
Apr 13, 2013 05:33 PM
harleycat225
Nov 8, 2011 12:31 PM
Brawny MMC
Mar 29, 2011 04:38 PM
cprice9
Jul 24, 2008 08:50 AM
RandyD123
May 17, 2006 11:08 AM
