Factory Headlight Upgrades?
Old Aug 15, 2010 | 06:05 PM
shiftharder's Avatar
shiftharder
PIAA makes a great replacement bulb - be careful - my buddy with a Dyna overtightened the chrome ring when replacing his bulb and the glass shattered - not enough play for heat expansion.
Old Aug 15, 2010 | 08:00 PM
Zenmervolt's Avatar
Zenmervolt
The most important thing I've done was to actually aim the light. When I got my XL1200R, the headlight was wildly out of aim, pointed at a spot about 15 feet in front of the bike instead of down the road as it should have been. I spent 15 minutes to get that right and suddenly the stock light was almost infinitely better at night.
If you do go the route of using a higher-power bulb, I recommend Osram's 70/65 watt H4 offering. Any higher than that and you risk damage to the stock wiring and plug by pulling too much current.
Old Aug 15, 2010 | 08:04 PM
xFreebirdx's Avatar
xFreebirdx
I put a brighter PIAA light in with one of those diamond cut housings. But the bucket was to shallow for comfort (heat). So I took a 1.5 inch of strap steel and hammered out the ring closest to the black bucket. Its made so the stock rubber mount still fit. Had it chromed. Works great.
Old Aug 16, 2010 | 04:42 AM
madmax442's Avatar
madmax442
Thanks for the suggestions guys!
Old Aug 16, 2010 | 08:08 AM
AaronG87's Avatar
AaronG87
I bought the upgraded bulb from hd a while back and I figured it may be a bit brighter but, wow it far exceeded my expectations even my dad commented on how bright it is.
DonN
Jan 28, 2013 09:02 AM
FD2
Nov 25, 2010 09:58 AM
Topspin
Sep 23, 2008 09:30 PM
BillyG0856
May 3, 2008 04:18 PM
dsuppa
Jun 12, 2007 12:47 PM
