backfire help please
Old Oct 9, 2010 | 05:52 PM
mattman89's Avatar
mattman89
Default backfire help please
i think my bike is running rich? when i get off the throttle it tends to back fire every few sec. till i pull in the cluth. how do i adjust it? its an 05 harley sporty 1200c, its still has a warrenty though. should just take it in and pay the 50$?
Old Oct 9, 2010 | 10:55 PM
WRAITH's Avatar
WRAITH
We need more info. What have you changed (exhaust, intake)? Also, pull your spark plugs. What color is the electrode insulator? Back= Fouled (to rich or to much choke). White= To lean (the front cylinder should be off white. Tan= Just right (normal for rear cylinder).
Old Oct 10, 2010 | 08:38 AM
mattman89's Avatar
mattman89
it has se pipes and the intake has the k and n air filter. im goin to pull the spark right now thanks.
Old Oct 10, 2010 | 08:55 AM
CheezHead's Avatar
CheezHead
Decel back fire is caused by being lean on the primary some call it the slow jet (not the main jet). Go up 1 or 2 sizes and the it will go away.
Old Oct 10, 2010 | 09:19 AM
mattman89's Avatar
mattman89
ok so i pulled them, the front has a tiny bit of black, but mainly tan. the back is barley tan...
Old Oct 10, 2010 | 09:39 AM
cHarley's Avatar
cHarley
I'm assuming that you acquired this bike used?
A K&N filter in the stock filter can does not produce a significant increase in intake airflow. However, a K&N filter in an SE can does, and would call for an increase in the Pilot (slow) jet size.
The stock pilot jet size is a #42. If you have an SE filter can and the SE pipes, you'll probably need a #45 pilot jet.
Your dealer service department should be able, with just a quick look, to tell you what type of filter can is installed on the bike.
Old Oct 10, 2010 | 01:51 PM
mattman89's Avatar
mattman89
yep got it used. i also have to bring it in for the 15,000 ,mile service. the dealer said it would be about 325$ for the service. is that expensive or normal for a stealer?
Old Oct 10, 2010 | 03:03 PM
Osco's Avatar
Osco
Account Deactivated
Cool $325
A very decent price,,,prolly means $325 + Parts n fluids tho.
Sep 1, 2015 06:45 AM
2oySprty
Nov 4, 2013 07:07 PM
Rog48
Nov 13, 2012 07:43 AM
Kodeman
Exhaust System Topics
Jun 10, 2009 09:29 PM
rah002
Jul 10, 2006 01:15 PM
