HELP! Bike won't start!
Old Mar 12, 2011 | 09:30 PM
scrunchee's Avatar
scrunchee
Default HELP! Bike won't start!
I have a 2008 Sportster 1200 Custom. Had the battery out of the bike for the winter and is fully charged. Went to install battery today and nothing is turning on. Not getting lights or anything at all. Checked all connections about 100 times and can't figure it out. Replaced fuses I thought were bad and still nothing. Am I missing something? Could something else be bad causing the bike to have no power at all? Please help!!
Old Mar 13, 2011 | 07:45 AM
cavalier2000's Avatar
cavalier2000
are you sure the battery is good?
you can test it or take a set of jumper cables connect to a non running car and then to your bike and see if you can jump it
Old Mar 13, 2011 | 07:58 AM
Mike T's Avatar
Mike T
+1 on the battery unless you're not getting any ground at all to it.
Old Mar 13, 2011 | 08:05 AM
Iceman24's Avatar
Iceman24
DON'T JUMP W/CAR...best way to fry your electrical! Test battery w/multi-meter, or get a charger!!!
Also, make sure you have the pos/neg posts on tight. When you had the battery out of bike - was it just sitting, or connected to tender?
Old Mar 13, 2011 | 09:26 AM
Blackcherry Low's Avatar
Blackcherry Low
Check your maxi-fuse, it may be blown, shuts down the whole bike.
Old Mar 13, 2011 | 09:43 AM
fcsallan's Avatar
fcsallan
Why does this "don't jump with your car" thing keep coming up?
Who is it that says jump starting a 12 volt system with a 12 volt system is going to do damage? The only damage that can be done is if you already have a problem that adding more power to will continue the damage. The same damage would be done with a fully charged motorcycle battery.
OP, I would remove the battery again, have it load tested and triple check your ground connections. If you have a VOM, make sure you have a great connection (0 ohms) between the negative terminal and grounds at a few places along the frame. That short little ground wire causes more problems than you could imagine.
I would also suspect your ignition switch if all is good there and no blown fuses.
Old Mar 13, 2011 | 10:12 AM
99superglide's Avatar
99superglide
I jump start the wife's Sporty every Spring with the car, not running of course no probs.
Old Mar 13, 2011 | 12:19 PM
streetfighter06's Avatar
streetfighter06
If it's ok for a Boeing 747 to jumpstart the space shuttle, I say +1 for jumping your bike w/ your car. I've done it a bunch of times with no issues.
Old Mar 13, 2011 | 12:38 PM
scrunchee's Avatar
scrunchee
Thanks for the responses. I'm gonna check the battery once more and also check the main fuse. Hopefully, that'll be it.
sonnyb3
Nov 28, 2014 06:23 PM
Rainmakr
Nov 13, 2012 11:54 AM
shanvhere
Oct 3, 2012 02:34 AM
ratWynx
Engine Mechanical Topics
Sep 18, 2010 03:06 PM
RealDealHog
Jul 18, 2006 02:46 PM
