help
Old Mar 16, 2011 | 11:21 AM
123rod123661's Avatar
123rod123661
1st Gear
Default help
i just got a xlx 1000 after i ride for about 20 miles it dosent shift in to first,when i first start out it shifts great,can anyone help me figure this out please.
Old Mar 16, 2011 | 12:10 PM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
What happens when you try to shift into first? Can you shift into all the other gears?
Old Mar 16, 2011 | 01:32 PM
123rod123661
1st Gear
at first it shifts perfect after 20 miles or it wont shift back into first i changed both trans and motor oil didnt help.
Old Mar 16, 2011 | 01:34 PM
123rod123661
1st Gear
it does shift to all the other gears but second and third have a little trouble
Mike T's Avatar
Mike T
Have you tried a shifter adjustment?
Old Mar 16, 2011 | 01:47 PM
123rod123661
1st Gear
no how do i do that
Old Mar 16, 2011 | 03:03 PM
Mike07FLHTC's Avatar
Mike07FLHTC
first I'd adjust the clutch and the cable
Old Mar 17, 2011 | 06:33 AM
guitarman023's Avatar
guitarman023
mine sticks every once in awhile, I usually bump it up into third and then shift back down through and it goes right in, but it doesn't happen very often. If it won't go in at all, and your shifter has plenty of clearance when you're shifting, it might be time to pull the gears for a quick look.
Old Mar 17, 2011 | 06:37 AM
nciron883's Avatar
nciron883
Bingo!
Old Mar 17, 2011 | 07:09 AM
Pixiechitos's Avatar
Pixiechitos
