2009 EFI 883L running rich? I think.
Old Mar 26, 2011 | 09:23 PM
vallokid's Avatar
vallokid
No XiED's found on the bike. Did a nice little ride today until cut short by thunderstorm and tornado sirens. Got 39 mpg today, in town driving and back roads about 50/50. Not sure why the mileage is so low. The bike runs great at low speed and while cruising the back roads around 55-60 mph. Still think it's running rich. I will check with the dealer that did the intake and exhaust and see which download was done. It is my understanding that only the dealer can do a download/remap. Is this correct?
Old Mar 27, 2011 | 04:46 AM
Osco's Avatar
Osco
Account Deactivated
Cool
Thats a YES for the HD Sert download,,,
I'm assuming you opend up the side covers n such looking for an
after market ecm add on device,,,,,,,
HD downloads are all EPA compliant lean or close to It,,
They can't go "Fat" on the AFR,,,,
The EPA would fine the crap outta HD if they caught em...
Old Mar 27, 2011 | 09:53 AM
volks-man's Avatar
volks-man
Hello everyone,
I recently sold my old metric and picked up an '09 883L. I already love the bike just after a few hundred miles. I have been checking my mileage and am only getting around 39 mpg. From everything I have read this is way off. I know this is not all related to my riding style, I'm old. I am the second owner of the bike and it had 1900 miles on it when I got it. It runs fairly well and has plenty of power. I have noticed that even on cold days when I start the engine it idles high only for about 5 seconds and then drops to regular idle speed. It does this cold or hot. It does blow a little bit of black smoke when revving when cold. I checked the plugs and they are a little brownish on top but mostly black around the electrode. It does also smell a little rich to me also. I have checked for exhaust leaks and found none. The bike does have SE air cleaner and SE slip ons.
So my question is can there be any other reason for running rich on this EFI Sportster other than someone has messed with the fuel mapping? Any suggestions appreciated.
Thanks in advance.
i don't see a problem here. you might be on the low side of the average but still within the limits of normal, i think.
my 2010 iron doesn't do much (if any) better.
the lowest i got before i stopped checking a while back was 39mpg. i am usually between 40 and 50 mpg but was almost always closer to 40 than 50.
i am running stock AC and dealer installed screamin eagle slip-ons. my dealer didn't re-map the bike..... at least they didn't charge me for it.... and they charged me for absolutely everything else!
Old Mar 27, 2011 | 03:14 PM
vallokid's Avatar
vallokid
Default Well look what I found.
Osco, you were on the right trail.
Here is the culprit, a SE race fueler. I've been looking all over the bike and here it was tucked under the wiring harness under the seat. Now I need to learn what to do with this thing. Should I chunk it and get something else, or keep it? I definitely will need to learn how to tune it. I'm sure there are some guys here that can tell me just what to do. I will be searching through the boards. Thanks.
LDB187
Jul 24, 2011 09:46 PM
aggiejason
Exhaust System Topics
Mar 14, 2010 07:55 PM
stbobber
Apr 18, 2006 07:06 PM
Mood Swing
Nov 26, 2005 08:07 AM
skyking
May 19, 2005 11:27 PM
