Bad Shocks Install?
Old Jul 25, 2011 | 08:53 AM
Voony's Avatar
Voony
Default Bad Shocks Install?
It just occurred to me that I might have just messed up the installation of my rear shocks. When I first put them on (before I lost 20 lbs), I could hear that bumping noise a lot. I thought I was bottoming out which did surprise me and then the noise disappeared. Two weeks ago I took my GF for a spin and we seemed to bottom out every foot. The both of us do not exceed 300 lbs in weight, and the shocks, the Burly slammer, are at their "stiffest" setting.
If you look at the picture below you will see how the top of the shocks hump the rails. I'm pretty sure it's not supposed to be this way, is it?
Old Jul 25, 2011 | 09:20 AM
mjolnir's Avatar
mjolnir
That doesn't look right to me at all. The shock needs to be able to pivot a little bit as the swingarm moves up and down, so the upper part shouldn't be touching anything. What bike is this?
Old Jul 25, 2011 | 09:42 AM
inswva's Avatar
inswva
You'll probably need to use some washers/spacers and possibly longer bolts to move the shock body away from the strut covers.
Old Jul 25, 2011 | 09:59 AM
Voony's Avatar
Voony
It's an 02 883C. I used all the washers and spacers that came with the bike. It does look completely wrong!
I'm going to contact Burly and see if they have a solution. Otherwise, where can I find spacers and longer bolts?
cHarley's Avatar
cHarley
+1 - There should be spacers installed top & bottom to move the shocks out away from the frame.
Installing "slammer" shocks and then running 2up at 300#, is bound to cause a bottoming out problem. It ain't rocket science.
Old Jul 25, 2011 | 10:10 AM
ironhide_uk's Avatar
ironhide_uk
its a little hard to see, is the marks on the rail or rear strut/rail cover?
Only ask as my 09 iron rear fender strut covers are open there around that section but yours seem to cover under there too
Will hit my pics to find a photo of what I mean
Old Jul 25, 2011 | 10:21 AM
inswva's Avatar
inswva
I'm sure you can find everything you'll need at Lowes or Home Depot.
Old Jul 25, 2011 | 12:03 PM
HOTLAP's Avatar
HOTLAP
You don't need longer bolts they are plenty long enough, just take one of your washers as a sample and get two or three stainless washers the same size for each side & install them to move the top of the shock away enough so it doesn't touch.
Old Jul 26, 2011 | 06:08 AM
Thumper26's Avatar
Thumper26
Something's definitely wrong with the way those shocks are hitting the struts. The top of the shocks should not be that close to the struts and since the top of the shocks, as well as the struts to which they are mounted, are "sprung weight" so they should never hit one another. My initial reaction is that they are not the correct shocks for your bike. No shocks should need to be mounted with so many wahers and spacers. Just my 2 cents worth...
Old Jul 26, 2011 | 06:12 AM
xFreebirdx's Avatar
xFreebirdx
+2 As said make sure that you add the same thickness spacers/washers to the top and bottom.
