Accent Light Installation
Old Aug 28, 2011 | 09:35 PM
crhothem's Avatar
crhothem
4th Gear
Default Accent Light Installation
Hey Guys. Brand new to the HD forums. I have a 07 Nightster. I'm working on installing a LED accent light kit on the bike. Only problem I'm having is finding a place on the bike to mount and wire the remote control antenna box. It's about the size of a cigarette box and shouldn't get wet or hot. It doesn't fit inside the battery cover. Ideas? I'll try to get pics up later. Thanks!
Old Aug 28, 2011 | 11:22 PM
ShAwTWiN's Avatar
ShAwTWiN
Question Cereal grain?
Same as (IMO):
Old Aug 29, 2011 | 06:25 AM
crhothem's Avatar
crhothem
4th Gear
Those light jobs look fantastic! Do you prefer LED strips or light pods?
crhothem's Avatar
crhothem
4th Gear
cereal grain?
Old Aug 29, 2011 | 08:39 AM
schwingding's Avatar
schwingding
I just yesterday installed a LED controller from ledglow.com on my girl's 09 Sporty. (in her case it really IS a girl's bike). It fit perfectly right under the saddle in a little recess literally right in the center of the triangle under a large connector. If your bike is like hers, there aren't many more spots available, but you might find room under the headlamp visor or on top of the ECU (if injected). One other possible spot I saw was right behind the engine on the firewall but this would be my last choice. If you relocated the coil and ignition key to the left side in between the heads you would be able to mount it where the coil now resides.
Here are two bikes I recently did (the vrod is mine)
Attachment 625251
Old Aug 29, 2011 | 11:14 AM
parabellum_9x19's Avatar
parabellum_9x19
I find my brake lights to leave a bit to be desired, so I think I may install some LED strips up under the fender, actuated by the brake lights.
That would allow me to hold the brake at night and light up a lot of rear of my bike to avoid getting rear ended at street lights.
But I need to wait until I raise the rear end a bit, I don't want to risk the tire ripping them off if I hit a nasty bump.
Old Feb 13, 2012 | 09:10 AM
Papi's Avatar
Papi
Schwingding how did you route your front fork lights on the sporty? Pictures?
Old Apr 13, 2012 | 11:35 PM
blk&blu's Avatar
blk&blu
6th Gear
Nice Job Schwingding.
Old Apr 14, 2012 | 04:56 PM
schwingding
I didn't. Those bikes in that picture are a road king and a vrod. Did not mount lights under the fork on the sporty, but I have no pictures of me not doing it either...
babaharley
Mar 17, 2018 07:02 PM
shagnasty
Apr 18, 2016 02:15 PM
paulies 07
Mar 28, 2013 08:42 PM
Pelonz
Jan 21, 2012 11:47 AM
cardboard
Sep 17, 2010 01:46 PM
