blinkers....
Old Mar 7, 2012 | 08:44 AM
RANGER73's Avatar
RANGER73
Originally Posted by roundy
Is that your bike in your sig? - looks sweet!
When you say tins, what did you have painted exactly? Engine covers? Did you remove them from the bike etc?
FYI, Tin= fenders and tank.
Old Mar 7, 2012 | 11:02 AM
89sport's Avatar
89sport
Are you still using front blinkers? If you remove the fronts and use only the rear they will just be a solid light when activated.
Old Mar 7, 2012 | 12:23 PM
XLsporty's Avatar
XLsporty
Yes I did swap out the front bulbs for LED and put LED gems in the rear. Now that you mention that I'll put the reg bulbs back in and give that a try. All wiring stayed the same as far as color goes. I had the "gas tank, fenders, chain guard, oil tank, rear frame rail covers" painted a dark metallic gun metal grey. I had to get away from that yellow. I'll post up pics when she's complete! Thanks again everyone for the suggestions! Hope its as simple as an equalizer bar.. Why will the 4 way flashers still flash is what stumps me????
Old Mar 7, 2012 | 04:02 PM
mreed's Avatar
mreed
Because LED's still pull a little resistance...but apparently not enough to trip your flasher. Your flasher won't work until it "feels" enough of a ground LED's won't produce much of a ground. However, when you ground all 4 at once (when the 4-way flashers are on) it is just enough to trip the flasher mechanism.
KevenW
Apr 18, 2013 07:29 PM
justmealwatts
Apr 6, 2013 12:28 PM
whylee
Apr 4, 2008 11:40 PM
garcon
Jul 2, 2007 08:52 AM
Roadie4
May 27, 2007 08:51 PM
