OK Im kicking myself in the *** here. I have to run a fuel line from the left side to the right side. My key is located between the heads and the horn is below how the hell do I run a line. I was thinking between the heads but wouldnt it be too hot and then a fire would happen????
Yes, your fuel line is routed between the heads. There's typically some of that wire loom stuff on the fuel line as added protection. It basically runs directly across in between the heads to the carb along with the vacuum line from the petcock to the VOES......But I'm not sure if the '92's had VOES'.
OK thanks, those are some nice bikes ride2. Ill post some before and after of mine it doesnt look like the same bike and I only had it for 2 weeks going on 3
yup '92 has the vacuum advance, so does my '87.... it's an evo thing
