Singing electronic fuel pump
Old Aug 24, 2012 | 08:51 AM
Fulcrum's Avatar
Fulcrum
5th Gear
Default Singing electronic fuel pump
Hello everybody, new to the forum here. I have a '08 XL1200C. Bought it new and shortly after the warranty expired I started to notice a high pitch sound, it wasn't there all the time, and then sometimes it would get really loud. But when ever I took it to the dealer it went away so they could never hear it.
During the years I have figured out that it is the fuel pump. When it gets above 95 deg outside and there isn't any shade it starts quietly. The hotter it gets the loader it sings, at 106 deg it sounds like a turbine.
There are NO performance issues, when I take it to the dealer and they bring it inside where it's air conditioned, it gets quieter-will shut up even. When I put in cool freash gas, it shuts up.
For the cost of a new fuel pump, no performance issues and the few months of the year that has this kind of temperature, and no will qarrantee that it won't start singing again, i let it sing when its hot. My question: Does anyone else have this issue?
Old Aug 24, 2012 | 08:55 AM
djw88's Avatar
djw88
Same here on my 08 Nightster rides great but sometimes on start up it "It sings" seem like if its been setting a few days it gets super loud
Old Aug 24, 2012 | 09:43 AM
Rokrover's Avatar
Rokrover
Yep - common issue. Factory says it's not a problem unless the pump fails. Think of the noise as a desirable option telling you the fuel pump is priming. Cheers, RR
Old Aug 24, 2012 | 09:59 AM
blindrocket's Avatar
blindrocket
Yup, happens to me too and several others on this forum.
Old Aug 24, 2012 | 12:21 PM
John Harper's Avatar
John Harper
My buddy had an S10 Chevy that sounded like a jet, the pump made so much noise. I guarantee that's not a good sound, and it will fail like his. I think it's overheating that causes the noise. They need to be in liquid for them to cool properly, so don't drive around a lot with a near empty tank.
I don't care what the dealer says, I'd get it replaced if it's under warranty (guess not). Otherwise, keep her full of gas and don't worry about it. Really not much else besides spending money when it eventually fails, could be years, months, days, minutes.
John
Old Aug 24, 2012 | 12:46 PM
Fulcrum's Avatar
Fulcrum
5th Gear
Actually..., when it has a full tank of gas - it's at its worse. If it's full then I can't put cooler fuel into it. I ride it daily, rain or shine and I live and work in the frying pan, north Dallas, TX area. Heat DEFINATLY is the cause of the problem. When I start it in the morning, it's fine. At lunch, as long as the temps stay below 95 deg. it's not a problem. But a 5pm, good lord the looks I get. IF and only IF I could find some shade to park it under, then when its out of the direct sun. The fuel dosn't get heated up. Like I said not a single performance issue. And for the cost of a new pump that may sing or not sing again, it can sing.
What I want is for Harley Davidson to fix this problem..., I love my bike but I would rather it not sing.
Old Aug 24, 2012 | 12:57 PM
John Harper
How about covering your tank with a thick white terrycloth towel. I do that to my ice chest when camping (helps to soak it with water big time!) and it keeps my food cold for so much longer. The white will reflect the sun and not absorb much heat.
John
Old Aug 24, 2012 | 04:36 PM
Fulcrum's Avatar
Fulcrum
5th Gear
I have been kicking around covering the tank somehow...
Old Aug 24, 2012 | 10:30 PM
JonFMJ's Avatar
JonFMJ
Could be a hose. There's a hose attached to the pump in the tank. Sometimes they end up with a pin hole in them and causes it to sing. I remember reading something about that a month or so ago.
Old Aug 24, 2012 | 11:04 PM
Fulcrum's Avatar
Fulcrum
5th Gear
I actually took the tank off the bike and removed the fuel pump last summer. I looked it over real close, really hoppin to see something obvious... but nada...
Jetfever
Dec 15, 2014 06:27 PM
11bDad
Sep 12, 2012 06:39 PM
09NightsterVB
Jul 9, 2010 07:28 PM
08HSTC
Mar 5, 2010 11:06 AM
boutellepc
Aug 11, 2008 09:25 AM
