Alittle smoke now hot positive.
Old Aug 27, 2012 | 01:53 PM
Mcnasby's Avatar
Mcnasby
Default Alittle smoke now hot positive.
While replacing my carb today and trying to restart the bike I smelt a small bit of plastic burning and alittle bit of smoke not much at all. I then saw a spark come from the positive wire right about at the terminal. The positive wire was also hot to the touch. Not taking any chances whats my next move here?
Mcnasby's Avatar
Mcnasby
Bike is 1993 883 sportster
Old Aug 27, 2012 | 01:55 PM
Judge1989's Avatar
Judge1989
Tighten the positive wire and try again. It may have been loose for awhile and you didn't notice. And a loose wire like that will be very hot to the touch. Burning plastic may have been the insulation on the wire.
Old Aug 27, 2012 | 01:56 PM
soft 02's Avatar
soft 02
Remove and clean the bat connections and re try. A loose connection will create heat and sparks. Also look for any bare wires or rub marks in the loom. This only happened when you tried to crank it?
Judge1989's Avatar
Judge1989
Better tighten the negative while you are at it too...
Old Aug 27, 2012 | 01:58 PM
12_Nightster's Avatar
12_Nightster
Also check the ground on the engine aswell
Old Aug 27, 2012 | 02:01 PM
Scaredofrain's Avatar
Scaredofrain
Sounds like a bad contact indeed. Bad contact is just like a too small a wire carrying a high load. The wire gets hot because there's not enough conductive material to transport the electricity, so what material there is has to carry more. The bad connection is a bottleneck so, get hot.
Old Aug 27, 2012 | 02:37 PM
Mcnasby's Avatar
Mcnasby
You guys are good. The positive had come slightly loose. Tighten connection next I'll pull battery and check for any wear on wiring.
Bill wallace
Shovelhead
27
Feb 16, 2021 08:00 AM
Rusty Axle
Shovelhead
Jan 20, 2019 05:20 PM
falconbrother
EVO
Oct 6, 2015 10:22 AM
ReidRik_Von
May 25, 2014 10:21 AM
drnk_n_publick
May 20, 2011 01:07 PM
