electrical problem
Old Aug 28, 2012 | 01:24 PM
knights's Avatar
knights
Default electrical problem
hi guys, i just installed my new set of road 6 custom zbars.
i wired the electrics internally.
when i finished, i tried everything and it all works great apart from my turn signals and my headlamp switch. as iv never used full beam yet, im not too heartbroken about it, but the turn signals is gonna be a problem.
my suspicions are a fuse or the wire isnt strong enough to carry the current for the lights.
as im not experienced in any of this, i could use some help from someone from someone who is
Old Aug 28, 2012 | 01:57 PM
paulbrad's Avatar
paulbrad
is it a bad earth? have you tried the wiring diagram?
Old Aug 28, 2012 | 04:33 PM
HBRHMR's Avatar
HBRHMR
Check the fuses...but make sure you're not pinching a wire first or you'll blow through a couple unnecessarily like I did.
Old Aug 28, 2012 | 04:51 PM
HeelDragger's Avatar
HeelDragger
If all your lights worked before you installed new bars, it's very likely that some of your splices came apart or some of the wires got chaffed when you pulled them through the bars. Check the wiring at the switch control housing where it enters the bars and also where it exits the bars in the center. If you drilled the bars yourself, did you file the holes smooth? Did you install rubber grommets or wire wrap between the wiring and the holes? If not it's likely the wires got chaffed or broken when you pulled them through. Also check the inside of the switch control housing to make sure you didn't pinch the wires or pulled them off of the switches accidentally when you screwed them together.
Old Aug 28, 2012 | 05:15 PM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
+1 on pinched wires.
Old Aug 28, 2012 | 05:20 PM
davidwruth's Avatar
davidwruth
Fuses only blow when shorting to ground when u try to work switch. If fuses aren't blown I agree check your splices
Old Aug 29, 2012 | 02:01 AM
knights's Avatar
knights
thanks guys.
the bars came pre-drilled.
im sure they didnt pinch at the control housing, as the holes were quite big.
my guess would be the wires came apart where i spliced them as i pulled them through.
damn it! it took me so long to get all the wires through and splice them.
i guess i gotta start again.
not today though as its raining pretty bad.
Old Aug 29, 2012 | 06:11 AM
knights's Avatar
knights
ok problem solved.
while thinking back to when i installed these, to remember if there was anything i could have done wrong, i remembered something.
while wiring the two wire of the right turn signal, i dropped the two wires. i had them labeled, but i had to cut them short because i estimated the wire too long (better too long than too short eh). so the part of the wire i chopped had the labels on.
when i dropped them i was almost certain i knew which was which and wired them accordingly.
this was the only possible mistake i could have made. so i thought worth a shot.
i pulled the wire (grip side) cut the wires and rewired them the other way around.
fired up the the bike, my indicators worked. yay happy me.
oh high beam works aswel
Old Aug 29, 2012 | 06:14 AM
Iceman24's Avatar
Iceman24
Good deal...and the high beam??
Old Aug 29, 2012 | 06:19 AM
knights's Avatar
knights
thanks iceman, yeah high beam works perfect :-)
Rollcage
Jun 29, 2016 11:55 AM
sportstersparky
Electrical/Lighting/Alarm
May 31, 2016 12:17 PM
Hoffy
Mar 29, 2009 11:02 PM
RAJ
Feb 14, 2006 04:18 PM
blukrom
Sep 3, 2005 07:00 PM
