Hot Dual brake disk
Bob
Also, there is no adjustment that you mention so that is definitely not the case.
As long as there is no mechanical interference from a mislocated caliper or rotor (highly unlikely), the problem is a piston(s) sticking in the caliper.
If all they did was replaced the pads then it's hard to place the blame upon them. Unless the piston was frozen you'd be hard pressed to identify any problem by simply replacing pads. In this case you would be responsible for getting the additional caliper work performed.
If they rebuilt or replaced the calipers and now you have this problem, then by all means they should be responsible to correct it.
Exactly, what does rebuilt mean?
First off your bike uses DOT 5 brake fluid. DOT 5 has both good and bad qualities which I'm not going to go into, but my car my Jeep and 3 bikes use DOT 5 and I'm not about to change.
Routine maintenance for brakes should include bleeding out the old fluid with new fluid every couple of years.
What does this have to do with brakes dragging and burning up when the ads get changed out you ask???
Before changing old pads if you look in your master cylinder you will notice the fluid is low.
Part of the reason for this is the old pad is thin and the calipers pistons are extended out farther as a result.
You will also notice the fluid looks dark, from heat, moisture, lots of stuff. Its gunky.
Its common practice for most back yard wrenches to clean the caliper from dust and road debris when doing brake work, good practice indeed! But what about the parts you cant see? Like inside the caliper.
Many people say "if you don't open the break system you don't need to bleed the system"
That's half right in my opinion. If you open the system you do in fact, need to bleed it.
But I also believe that a major reason for a caliper to drag or even lock up is because when you squeeze the piston back into the caliper the dirtiest fluid in the whole system, the fluid that sustains the most temperature change, is the fluid inside the caliper.
It's kind of a pain to do but ever since I started first bleeding my brakes until the clean fluid comes out "before" putting the new pads in I have not had to rebuild or replace any calipers.
Sure it's a pain getting the spongy out of dual disc fronts but compared to rebuilding or replacing the calipers (which BTW also needs to be bled) its not so bad, you eventually get pretty good at it.
There ain't no garage that does it this way. That's why the above poster noted that brakes are too important to let some mechanic work on. Do your own if you can.
That's how we learn!
