remove rusty spokes on nightster
Old Aug 5, 2013 | 08:53 PM
Frank Gomez's Avatar
Frank Gomez
Stage III
Default remove rust from spokes on nightster
Hello. I have a nightster 2008. The spokes have gotten quite rusty.
Does any one know the best method to remove it?
Im going at it with steel wool and it kinda works but I need some chemical that helps loosen up the rust without damaging the spokes.
I don't think the spokes are chrome, but I may be wrong.
Also is there anything i can apply to the spokes once I clean them completely that inhibits the rust from coming back?
Thanks
Old Aug 5, 2013 | 10:20 PM
laffin gas's Avatar
laffin gas
check out bykas for some spoke wraps....easy way to make your bike custom.
either that or send the spokes out for chrome and get it relaced or send them for powdercoat....I use a polish from surf city...metal polish...best chrome polish I have ever found. I have almost every other brand and nothing comes out as nice as the surf city stuff. easy to apply and easy to take off. spokes are not the most fun to polish and it takes a long time to do. easiest way is to take the wheels right off the bike and grab a seat and have at it....on the bike is much harder going side to side and constantly spinning the wheel and so on....but once they are clean make sure you clean them often and polish them. if you keep them polished they are easy to maintain.
Old Aug 5, 2013 | 11:09 PM
DallasSportster's Avatar
DallasSportster
http://www.amazon.com/chefgadget-1733-Wenol-Metal-Polish/dp/B0000DE4QE http://www.amazon.com/chefgadget-1733-Wenol-Metal-Polish/dp/B0000DE4QE
This stuff took the rust of my spokes and haven't had any since. Been using for years on all types of metal.
Old Aug 5, 2013 | 11:49 PM
Sharpie's Avatar
Sharpie
Shoe laces,
Chrome Polish,
6.5 hours
You may need more than one pair of laces. Flat type not round ones. Put the bike up on a jack stand. Its easier to work while sitting in a low chair.
Old Aug 6, 2013 | 12:11 AM
$eventy2T's Avatar
$eventy2T
6.5 hours? ^^^^ lmao. It takes me about an hour to get them near spotless, chrome or no chrome. Brake dust or rust.
I'm a spoke freak. 1. That probably (need pics) isn't rust but caked brake dust. Some guys use a detailer's wheel acid or Ez off oven cleaner for the tough spots and immediately rinse. Scotchbrite pads are available for dremels and also make a thin pad (which does the same as laces but covers more area).
A semi Abrasive metal polish works to loosen and the Scotch pad will remove it. a good quality toilet brush helps get the grit out of the nooks.
Hot brake dust sticks to everything including chrome. Hope this helps. (careful w the Ez off..... remove wheel, golves etc.....)
Old Aug 6, 2013 | 12:16 AM
DallasSportster
I took me less than an hour with a rag and the polish mentioned above. No abrasives and no wheel removal. I had rust spots on every spoke.
Old Aug 6, 2013 | 12:32 AM
dtaylor00's Avatar
dtaylor00
CLR works good to take the rust off. Eagle 1 wadding polish works well to polish
Old Aug 6, 2013 | 07:04 AM
nauzerlvr's Avatar
nauzerlvr
Give this stuff a try - "Naval Jelly". I've used it before on other rusty things and it works really well. I'm not sure about letting it get on paint though.
http://www.loctiteproducts.com/p/s_t...-Dissolver.htm
asianiron
Feb 3, 2016 11:57 AM
Bubba Zanetti
Sep 12, 2015 09:28 AM
tandt
Dec 23, 2012 09:56 AM
klf33
Dec 20, 2009 01:09 PM
GoOdGoD1763
May 31, 2009 05:46 PM
