So after a person on this forum scammed me into buying an exhaust that wasn't as promised, I am trying to retro fit my exhaust on. After a million headaches and mods I need some help. My question is...what exactly is this wire mesh exhaust seal called? Are they necessary? Where can I buy new ones? Or can I just bend it back into about the right shape? Please share any wisdom you have!
They are called what they are, exhaust manifold gaskets (or seals). I have not replaced mine, but you can buy them at Harley. I think they even make a Screaming Eagle version that may or may not be worth the extra expense. I think the hard part is getting them in there properly and installing your headpipes carefully.
It looks like yours may have been intruding into the exhaust port a bit, fairly common from what I've read.
I don't think they are more than a couple bucks each. Why mess with the old crap?
I would say they are "necessary." For sure.
Sorry about the pipes, I thought you said it was a Vespa, not a Sportster. Hey, a girls bike is a girls bike.
John
Before you RETRO FIT anything, I would post your issues on the forum. Just trying to keep you from creating more problems since you didn't know what the exhaust gasket was..Its great your doing your own work. Been there myself
Those exhaust gaskets can sometime be a real pain to install into the exhaust port of your engine head. One trick that has worked for me is to put them in a freezer for a few hours. The cold makes them shrink just enough to ease them in the port.
I have used the James copper gaskets with good success.
Genuine James Copper Crush Exhaust Port Gasket - JGI6532483CG
They are consumables, available at every Harley dealer and indy. Having dug the poor thing out, give it a decent burial. As with so many things in life, fitting new ones requires a little patience and sleight of hand.
get the proper new seals..
a air leak that close to the valves can cause them to warp/ruin seats.
cold air on hot valves ( as in shutting off the motor) aint good .
Get these or an equivalent like the coppers by James gaskets.. Used on my install. Pushed them in by hand working them around the port. Fit nice and give that extra depth into the exhaust port to accomadate a deeper head pipe. Be sure to torque to 120inch lbs iirc.
